CLOSED
is it possible to clone a ticket on another project and update comments, status and attached documents on both projects, when changes are made on the firts, update is made on the 2nd
thank you
CLOSED
This is Majid @ Exalate.
The flow you described should be possible using Jira Automation or by using an issue sync app such as Exalate. You can use the local mode of Exalate to connect the two projects, use a JQL trigger to automatically send the tickets over and maintain a sync between the two.
Majid
Hello @Alixanne FERAUD
We developed an application called Copy & Sync that does exactly what you need. It will allow you to copy and synchronize issues between projects with all informations you need (comments, status, attachments, fields, etc.).
All changes made on one size will be made on the other.
You can take a look at what our app can do in our documentation (some of it).
Let me know if you need help with that!
Regards
Hi Alixanne,
Sure you should be able to do that. Create a trigger that will Clone or Copy the Issue. Then add a step (i.e. component) to the rule Link the two projects.
So, after you do the action to Clone or Create a new issue, the add a Branch for Most Recently Created Issue. Under the branch add an action for Link Issue. Choose Trigger issue.
Hi John thank you, i 'm gonna try tight know and let you know
regards,
Hello @Alixanne FERAUD ,
Welcome to community!
Yes it is possible through setting up automation rule, could you please elaborate a little on your use case that include: desired trigger , Condition and action item to perform. I may try to help you in configuring the setup for automation rulr.
Also please help understand the below line to help you better:
Have a great day!
HI
thank you :)
i want to be sur that if i made chages on the original ticket, updates are made on the cloned one, and reverse.
So i have to made rules on both project i think it's too heavy for our needs
thank you
HI
When ticket is moved to "selected for devlpmt"
and if composant equals XXXX
so clone ticket to projetc XXX
i want that : comments, attached documents, assigned to, when updated on the original ticket, updates are made on the cloned one, and reverse.
Where to i have to add branch and how to do it
i really appreciate you help, it's very kind.
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻♂️Online forums and learning are now in one easy-to-use experience.
