create issue through API
vashim shekh
Dear Sir,
Create BUG issue through API but error is coming that Fixversion Screen Not set.
Bug screen Fixversion filed available and mandatory.
There is way to short the issue.
Sandesh Shetty
January 11, 2021
@vashim shekh
Please find the doc. link to create issue throgh api https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-rest-api-3-issue-post
you can set the Fixversion field while creating issue for. eg like this
"fixVersions": [
"id": "10001"
vashim shekh
We are trying to raise defects in Jira using Jira rest apis. Please find below details regarding the api we are using.
URL : https://jira.devops.idfcbank.com/rest/api/2/issue
Input:
{"fields":
"summary":"Invalid bug raised from api",
"issuetype":{"name":"Bug"},
"project":{"key":"APIF"},
"description":"this bug was raised from jira rest api to test qrace integration",
"customfield_10404":{"value" : "Medium"},
"customfield_10403":{"value" : "Development" },
"fixVersions":[{"name":"TL - Origination Bouquet" }]
"update":{
    "issuelinks":[
          "add":{
              "type":{
                  "name":"Relates"
                "inwardIssue":{
                    "key":"APIF-1138"
We are not able to generate defect using api. We are getting following error :
    "errorMessages": [],
    "errors": {
        "fixVersions": "Field 'fixVersions' cannot be set. It is not on the appropriate screen, or unknown."
Sandesh Shetty
January 11, 2021
@vashim shekh
Please check create issue screen of bug issue type. whether fixVersions filed is available or not on that screen? also check "TL - Origination Bouquet" value is available in project Releases.
Like • 2 people like this
vashim shekh
we have checked already all components is there.
Sudarshan
January 11, 2021
Hello @vashim shekh
Are you trying to Create a Bug? or a Defect.?
sometimes a Defect is of issue type sub-task and not parent, your approach is correct.!
Note:
Hope you are aware of the policies of your organization when providing client specific URL: https://jira.devops.idfcbank.com/rest/api/2/issue
(though this cannot be accessed by every Atlassian community member)
If it is a site-specific query, I would suggest directly contact the Atlassian support
(it is a better practice)
vashim shekh
@Sudarshan @Sandesh Shetty
thanks to you sandesh and sudarshan also , we have fixed now there is permission issue we found.
Thanks.
FREE
Register now
