×Hi,
i have just created a custom field, showing all projects in a list view while creating a epic.
but its not visible in the epic side bar, so looking deeper i saw "We can't show this field type in the new issue view yet, but we're working on it."
doese anyone know how long will it take to show up?
Hello @Christian Mahlknecht ,
First off we are collecting feedback and tracking features relating to the new issue view at the following Request noting the list of child issues for the works in progress:
To make sure I can get you looking at and following the right feature request for this field, what is the field type for your custom field?
Also if this is a critical field for your workflow you can disable the new issue view to have access to the field by:
Earl
thanks for your answer.
The field i want to show in issue type is "Project Picker (single project)"
Do you want that i open a new task in the link indicated?
The Feature request to Enable the 'Project Picker' field in the new issue view is on the list and can be viewed here:
We are working on this one, but please do make sure and add a vote to the request to indicate that you are being impacted by this to help us with prioritization efforts as covered in the "Implementation of New Features Policy" , and you can also add yourself as a watcher if you would like to receive updates on the status when it gets added in.
Earl
Register Now
