delete status from workflow
jeroen_wilmes
June 14, 2023
Just to be sure:
I have a status in a workflow. That status is also used in other workflows.
If I delete it from my workflow, does it remain on other workflows?
(I'm aware that before removing I have to make sure that the workflow in not active)
3 votes
John Funk
Hi Jeroen,
Correct - removing the Status from a workflow will not affect the other workflows where it might exist. But only remove it from within the workflow.
jeroen_wilmes
June 14, 2023
thanks very much for your quick reply.
Like John Funk likes this
John Funk
Happy to help!
