deleted validation rule still working !!!
IOANNIS POLITIS January 28, 2021
i use Kanban board , and try to move a task from Backlog to Proccess column , but a pop window ( below ) appears , and ask to fill task time ( error in greek ) . It is a validation rule that i deleted from workflow . And i can't move no one task to this column .....
i try to delete this column and create a new one .... but still works !!!!
Jack Brickey
January 28, 2021
You have a Validator in your workflow on the transition to the Process (?) status. Remove it if you don’t wish to require the due date be set. Also remove the screen from the transition if desired.
IOANNIS POLITIS January 31, 2021
Thanks for your answer , i found the validator and delete it
Kai Schmidt
January 28, 2021
this may be a required field in the field configuration?
thanks , it is a required field but it has to do with validator in transition .
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
