differing GraphQL responses with issueSearchStable
Steve Maring September 7, 2022
In the browser-based GraphQL explorer for my sub-domain at https://hv-eng.atlassian.net/gateway/api/graphql  I can specify a query:
query getProjectAttachments {
jira {
issueSearchStable(first: 100,
cloudId: "<MY_CLOUD_ID>",
issueSearchInput: { jql: "project = '<MY_PROJECT_KEY>' AND attachments IS NOT EMPTY" } ){
pageInfo {
endCursor
hasNextPage
edges {
node {
key
webUrl
attachments{
edges {
node {
attachmentId
fileName
fileSize
with header request:
"X-ExperimentalApi" : "JiraIssueSearch"
and get results populated properly
If I try to translate this over to a curl command I get a DecodingException
$ curl -s -X POST \
--header 'Content-Type: application/json' \
--header 'Accept: application/json' \
--header 'X-ExperimentalApi: JiraIssueSearch' \
--header 'Authorization: Basic <MY_BASE64_ENCODED_EMAIL:API-TOKEN>' \
-d "{ query getProjectAttachments { \
jira { \
issueSearchStable(first: 100, \
cloudId: \"<MY_CLOUD_ID>\", \
issueSearchInput: { jql: \"project = '<MY_PROJECT_KEY>' AND attachments IS NOT EMPTY\" } ) { \
pageInfo { \
endCursor \
hasNextPage \
edges { \
node { \
key \
webUrl \
attachments { \
edges { \
node { \
attachmentId \
fileName \
fileSize \
"https://hv-eng.atlassian.net/gateway/api/graphql" | jq '.'
"timestamp": 1662593267335,
"path": "/central/graphql",
"status": 400,
"error": "Bad Request",
"message": "Failed to read HTTP message",
"requestId": "59a78998-5304466",
"exception": "org.springframework.core.codec.DecodingException",
"request_id": "UNKNOWN",
"query": "unknown",
"operation": "unspecified",
"schema": "unspecified",
"errorSource": "GRAPHQL_GATEWAY"
Running this same query in Java it seems to accept it but it returns zero results:
"data": {
"jira": {
"issueSearchStable": {
"pageInfo": {
"hasNextPage": false
"edges": []
"extensions": {
"gateway": {
"request_id": "5cfe11d3d159581b",
"crossRegion": true,
"edgeCrossRegion": false,
"deprecatedFieldsUsed": []
I guess I have a couple issues here.  I don't see anything wrong with my curl query that would cause a DecodingException.  I'm much more concerned about not getting any data in my Java process though, as that's where I intend to do my data processing.  Does the web-based explorer have a broader permission set somehow?
