enable wiki markup editor in jira cloud
Steve McAfee November 14, 2016
I can't seem to get the wiki markup editor to show in JIRA Cloud. The wiki renderer is selected for the field (description) but all I get is a checkbox and x at the bottom right. None of the markup controls. Information about how to actually enable this seems non-existent. The Rich Text Editor addon says this is included automatically in cloud and then says nothing about how to enable it. I even found a ticket where someone wants to know how to disable it, but I'm stuck figuring out how to get it to show. That is, there is no edit bar above the field when it is being editted which shows bold, italics, etc. Any suggestion?
steve
Sam Hall
November 14, 2016
HI Steve,
Just to check: you don't have the control bar collapsed. The UI is a bit subtle if it is. See: http://gph.is/2eZ1p8Y.
The other thing to double check is that the 'Wiki Style Renderer' is definitely set for 'Description' in the field configuration that applies to your project.
Go to https://<URL>/plugins/servlet/project-config/<PROJECT-KEY>/fields, but replace URL with your JIRA site name (i.e. something.atlassian.net) and <PROJECT-KEY> with your project key.
You should see an entry for Description with 'Wiki Style Renderer', like this:
Sam
Steve McAfee November 15, 2016
Aack, you are right about the renderer. I was looking at the field configuration but the project was not using that configuration! Thanks, you can resolve this.
Sam Hall
November 15, 2016
Hi Steve,
Glad you found the cause and happy to help.
To resolve this, you can mark my answer as accepted, by clicking the tick next to it to turn it green.
Sam
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
