×I logged work against the wrong issue in JIRA, and need to understand how to remove it.
I sent this work-around to my team:
You can now edit your work log (assuming you have the correct permissions to do so). You can revert the view back by following steps 1–3 (except check vs. uncheck the box).
Thank you Jesse — much appreciated! This work-around worked. Beside, I think I will stay with old issue view. It's more compact and easier to read for me. I will miss harvest tracker in sidebar though.
Steps 1,2 & 3 are actually not necessary. You can open an issue from the board and click the issue id in the upper left. And then click "See the old view" and then at the bottom you should see the Work Log subtab
Thanks Mickey. I noticed that too a few weeks after posting here. So there is a semi-permanent and a very temporary method :)
I've that permission to ANy logged in user, but there is no option to delete own worklogs.
same problem here. I have all permissions but there is no trash icon
Same problem here.
Indeed
I only can see it if i click on "See the old view"
I struggled with this a bit myself before realizing that beside the "activity" label is a button you can press that reveals the other "activity" views you can switch to, including Work Log.
It seems that there's no workaround yet for next-gen projects?
If you click into the ticket - next to the Activity heading (at the bottom of the ticket) you can click "Comments" and flip it to "Work Log" and then you can delete or edit an entry
I sent this workaround to my team:
You may notice in Jira that when you switch from “Comments” to “Work log” while viewing an issue, there is no option to edit previous work logs for that issue.
This could change at any given moment since we have no control over Jira’s updates, but as of right now if you need to edit/delete a work log:
You can now edit your work log. You can revert the view back by following steps 2–4 (except check vs. uncheck the box).
You can now edit your work log. You can revert the view back by following steps 1–3 (except check vs. uncheck the box).
