how do i prevent linking issues to a closed epic
Deleted user March 16, 2023
how do I prevent linking issues to a closed epic
Ash Yadav
March 16, 2023
Hi @[deleted] , Welcome to the Atlassian Community!
Have a look at this thread: https://community.atlassian.com/t5/Jira-questions/How-to-prevent-epic-linking-issues-to-epics-of-a-particular/qaq-p/936417
A similar question appears to have been asked already it seems.
Generally speaking you can achieve this by setting up a workflow condition that prevents the linking of issues to closed epics.
There are some limitations on Jira Cloud as you'll later find in the thread.
Hope this helps.
Kind Regards,
Ash
Hila Lahav Rice July 12, 2023
thanks, but preferably if we could prevent it while the link  is performed and not after. that will reduce allot of errors, like permissions on edit for the EPIC.
Lucian Dragomir June 21, 2023
Hi @[deleted]
try the below automation.
How it works: when a ticket is updated it checks if it has a parent Epic and if that Epic is in statuscategory=Done or "Epic Status"=Done (I'm using Related issues condition, with Related issues: Epic, and condition: Matches specified JQL, with Matching JQL: statuscategory=Done or "Epic Status"=Done), and if the ticket is not Done (statuscategory!=Done) then it deletes the Epic Link and notifies the initiator through an email with this content:
ticket <b><a href="{{Issue.toUrl}}">{{Issue.key}}</a></b> was added to or is linked to <b><a href="https://your-instance-goes-here.atlassian.net/browse/{{issue.epic.key}}">{{issue.epic.key}}</a></b> which is a <b>{{issue.epic.status.name}}</b> Epic.
Please check it as adding <b>open</b> stories to already <b>closed</b> Epics should be avoided as it is not a good practice (as alternative please open a new epic and move the open stories to the new created epic).
<b>Be aware that the Epic link field was cleared.</b>
Thanks.
Lucian
