hi
i wanted to switch from clickup to jira and i wanted to know how can i import my project from clickup in jira?
We’re looking for feedback on an import experience we’re building, and would love to invite you to take part in an upcoming customer study!
What’s involved in the research:
Interested in taking part? Follow this link https://www.userinterviews.com/projects/MKTtUWU-Sg/apply to fill in a few more details so we can make sure you’re a good fit.
If you have any other questions at all, feel free to reply to this message or email me directly on yyin@atlassian.com. We look forward to meeting you!
Ying
could you please say why you would like to switch from clickup to jira?
Best regards,
Vera
I am thinking of doing the same.
One of the main reasons is I cannot use a unique ID in my click ups to track an issue or a user story. It doesn't allow search by the unique key. I need to search it using name or title or combination of filter fields.
I was on Jira before but then I jumped to Click up because they were so flexible.
But having a unique key that can be used in searches is more valuable than flexibility.
I am not familiar with clickup but if you can export your data into CSV file then you can also import it in Jira. Take a look at the documentation for more details. You first need to setup and configure your projects, map the fields and few other things for the import to work.
Apart from that you can also use Jira REST API or the JSON import as well.
I hope it helps.
Ravi
I believe clickup has CSV export capabilities as well.
Here is a code sample which moves from ClickUp to Jira
