how to set automation rule if any team member does not update his work log by eod
Shasheekant Patel
how to set automation rule if any team member does not update his work log till 5 PM every day in Jira then received an automated reminder mail.
Antuan Sammak
December 1, 2023
Hi @Shasheekant Patel
rule scheduled, mark it to run every day
i have the same rule but i run it every day at 8AM to check for the tickets that were closed the day before, however you can adjust it the way you see fits to your needs.
also my condition under the IF should be adjusted based to your needs, as for this example i added all options (label/component/team)
December 1, 2023
What have you tried thus far to solve this problem?
If you have started a rule, please post an image of your complete automation rule, images of any relevant actions / conditions / branches, an image of the audit log details showing the rule execution, and explain what is not working as expected.  Those will provide context for the community to offer ideas.  Thanks!
If you have not yet started a rule, please note that using automation rules requires learning and experimentation.  This community is not a free labor pool to implement rules upon request.
I recommend you try creating the rule, and if you run into challenges to ask the community for help.  To get you started on creating your rule, please refer to these documentation and example sources:
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
