how to use a conditional smart value
ben friedman June 13, 2021
i need to edit a value based on a smart value result.
i have an edit action where
{{#issue.issuelinks}}{{#if{{equals(type,"blocks")}} {{inwardissue.key}}{{/}}{{/}}
however, the condition isnt working!!
i tried it as simple as {{#if{{equals("2","2")}} x {{/}} and couldnt get to print x.
where am i missing it?
3 votes
Hauke Bruno Wollentin
June 25, 2021
@ben friedman absolutely no idea why, but you need to add spaces in front of `if` and the closing `/`
{{ #if{{equals("2","2")}} x {{ /}}
A comment in the following article led me to this strange one: https://community.atlassian.com/t5/Automation-articles/New-automation-smart-values-in-Jira-Cloud/ba-p/1402775
June 25, 2021
Hi @Hauke Bruno Wollentin  -- Welcome to the Atlassian Community!
Thanks for that reminder about the spacing, and... your link seems to have some extra chars making it fail.  Here's one that works:
Best regards,
June 14, 2021
Hi @ben friedman
Based upon the way the JSON/smart values are structured for links, I am unclear how you can do that directly in conditional logic: the link type appears to be in a separate node above the list of linked issues.  You might be able to use string functions to put the entire string into a created variable and then use string functions with a regular expression to parse it.
Or...have you considered  using JQL with LookupIssues, and then test the count/process the remaining issues?  Something like:
issue IN linkedIssues({{issue.key}}, "blocks")
Best regards,
Get Certified! ✍️
