how write the expression that attachment is not null
Sunilkumar k
How to write the Jira Expression that attachment is not null
Oliver Siebenmarck _Polymetis Apps_
June 14, 2022
Hi @Sunilkumar k ,
With Jira Expressions, the attachment attribute is never null – it's always a list.
Now, if you want to check if there's an attachment to your issue, here's how to do that:
issue.attachments.length > 0
Above expression will be false unless an attachment has been added to the issue.
Hope that helps,
 Oliver
Sunilkumar k
Thanks @Oliver Siebenmarck _Polymetis Apps_ , its working fine as i need now
Rob Horan
June 14, 2022 edited
Hi @Sunilkumar k ,
You can use the following JQL:
Search for issues that have attachments:
attachments IS NOT EMPTY
Search for issues that do not have attachments:
attachments IS EMPTY
Sunilkumar k
Hi Rob Horan
It is throwing me a error i need jira expression to write in the custom validator that allow if attachment is some type or allow if attachment is null,
i am able to allow only excel attachments but i need to write the expression to allow if the attachment is null, an you please help me on this please
Rob Horan
June 15, 2022
Hi @Sunilkumar k ,
That wasn't really clear.  I assumed you were searching based on attachments.
FREE
Help us plant more trees
