issue is status done but report is unresolved
Deleted user July 19, 2021
Hi teams,
We are using Jira Dashboard to help review our projects. Our issue is done but remained unresolved within our Create vs. Resolved Chart.image001.jpg
We tried to fix this issue and follow to document: https://confluence.atlassian.com/jirakb/jira-issues-need-a-resolution-826873869.html , clicking"Publish Draft" after executing Workflows. However, it remained the same result.
We checked the project's Workflow (as shown below).
Here is the question: How do we make our status "Done" and the Resolution "Resolved"?
Thank you for answering the question!
2 accepted
3 votes
Ashu Tyagi
July 19, 2021
@[deleted]  After looking at screenshot of your postfunction i found that second postfunction clears the resolution so even if you set it using the first postfunction second one clears it. You need to either remove/delete the second postfunction
Jack Brickey
Yes remove #2 and if you want the resolution to be “resolved“ rather than “done” then edit number one and change the value. Finally you also want to clear the resolution field on all of your other transitions. So basically add number two into the transitions into to do in progress and in review. Note this is not required on the create transition.
Like Steffen Opel _Utoolity_ likes this
Vessie Dracheva September 23, 2021
Hi there, I don't have #1 at all & I don't see an option to add it - how can I fix this?
Thanks in advance!
KAGITHALA BABU ANVESH
July 19, 2021 edited
Hello @[deleted] ,
If you need the issue statuses change to "Done" Status automatically based on any field value.
You can consider "Jira Automation" if you are a cloud customer.
Thanks, @ASHU TYAGI, I agree with you. I did notice. Thanks for the Flag.
Anvesh
Jan Šimek
April 14, 2022
Hi I have been using JIRA automation in cloud version and it gets to status DONE and it shows DONE, but even in done it is unresolved. I did not get the right way, how to do it? Can you help?
Deleted user July 21, 2021
Now the problem is solved. Thanks everyone for answering!
