issueslinks does not work
Leena Pratheepan
I would like to see my dependent task. For example I have: Task 1 blocks Task 2. and the other way around Task 2 is blocked by Task 1. How can I search for issues that are blocked.
Suggestion would be :
project = "PROJ" AND linkedIssues IN ("PROJ-107")
project = "PROJ" AND linkedIssues("PROJ-107")
But JIRA shows me an error message.
How can I solve it?
Ditte Simard
Do you have scriptrunner installed?  If you do, you can use this function:
issueFunction in linkedIssuesOf("issuekey = blah", "blocks")
Admittedly I have been using scriptrunner for so long that I don't know any other way to search for linked issues!  Lol
Leena Pratheepan
No, Problem. Thank you for your comment.
Ditte Simard
I dug into this a little further and you should be able to run this function out of the box without Scriptrunner:
"issue in linkedIssues(PROJ-123", blocks)"
Like • Leena Pratheepan likes this
Leena Pratheepan
Yes, it works, thank you :)
Like • Ditte Simard likes this
