jira automation accessing project properties
Luc Noppen May 24, 2022
Is it possible with a jira automation rule to get a jira project property?  You specify the project property key and you get the project property value. I already searched in the available smart values but didn't find anything.
2 accepted
May 24, 2022
Hi @Luc Noppen
You can read the entity properties, as is shown here for issues: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#--issue.properties--
For a project property, it would be:
{{project.properties."myPropertyName"}}
The key is context...if the trigger is for a project, use above.  If instead it is for an issue you might need to explicitly call the REST API from a web request in the rule to get the project to access the properties.  Before trying that, perhaps first try {{issue.project.properties."myPropertyName"}} to see if they are available.
Luc Noppen May 30, 2022
I'll test this before accepting the answer.
Thanks for your reply.
Kind regards
Like Bill Sheboy likes this
Alberto Salvante
May 24, 2022
Hi Luc,
what do you mean to get the jira property? What is your purpose?
If you mean to edit the property in automation there is a specific section to do that.
Hope it helps.
Best,
Alberto
Mykenna Cepek
January 19, 2023
I know this answer is tagged for Cloud, but I could use the answer for Data Center. I've tried both:
{{project.properties.snji-comments}}
{{project.legacyProperties.snji-comments}}
The value is set, as I can retrieve it with:
https://jira.company.com/rest/api/2/project/PROJ/properties/snji-comments
January 19, 2023
Hi @Mykenna Cepek
I am using Jira Cloud, not Server/Data Center, and...I wonder if you can find an issue in the project and access the properties that way with:
{{issue.project.properties.snji-comments}}
My understanding is the {{project}} smart value only works with the project-based triggers so perhaps that's why the smart value doesn't work for Server/Data Center version.
Mykenna Cepek
January 26, 2023
Bingo! @Bill Sheboy to the rescue!
I changed the rule from using a Scheduled (project-less) trigger to using a Manual trigger, which put the execution in the context of a specific issue (and project).
Bill's smart value worked, as did one of my original guesses, as shown below.
Since this is a single-project (not Global) rule, one might reasonably wish that the project.properties... smart value would resolve to the only project that the rule is scoped to.
With your answer I'm able to set a project property and with the answer of Bill Sheboy I'm able to read the project property.
Your answers combined give me what I need.
Thanks.
