×Hi @Arunraj,
How much RAM do you have allocated for the Jira virtual machine?
I recommend setting JVM_MINIMUM_MEMORY = and JVM_MAXIMUM_MEMORY = to the same size, but never more than half of the total allocated RAM.
Please refer to Startup check: Increasing JIRA application memory limits and increase your JVM memory accordingly.
Pavel
hai @Pavel Junek
Thanks for the reply but JVM_MINIMUM_MEMORY = and JVM_MAXIMUM_MEMORY = same thing i tried but it was not working.
and how to check how much RAM i allocated to jira
Oh, is there anything else written in the <Jira-home> /logs/atlassian-jira.log file?
I mean the total RAM allocation for the entire operating system where Jira is installed - the way to verify this depends on whether you have Windows or Linux.
12-Apr-2021 12:09:20.577 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/8.5.57
12-Apr-2021 12:09:20.586 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Jun 30 2020 21:49:10 UTC
12-Apr-2021 12:09:20.586 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 8.5.57.0
12-Apr-2021 12:09:20.586 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 10
12-Apr-2021 12:09:20.586 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
12-Apr-2021 12:09:20.586 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
12-Apr-2021 12:09:20.586 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Users\Arun Raj\Atlassian\Jira\jre
12-Apr-2021 12:09:20.586 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_275-b01
12-Apr-2021 12:09:20.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: AdoptOpenJDK
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Users\Arun Raj\Atlassian\Jira\conf\logging.properties
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms384m
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialCodeCacheSize=32m
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:ReservedCodeCacheSize=512m
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.standalone=JIRA
12-Apr-2021 12:09:20.594 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true
12-Apr-2021 12:09:20.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dmail.mime.decodeparameters=true
12-Apr-2021 12:09:20.606 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory
12-Apr-2021 12:09:20.607 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:-OmitStackTraceInFastThrow
12-Apr-2021 12:09:20.608 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.locale.providers=COMPAT
12-Apr-2021 12:09:20.608 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
12-Apr-2021 12:09:20.608 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
12-Apr-2021 12:09:20.608 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xloggc:C:\Users\ARUNRA~1\ATLASS~1\Jira\bin\..\logs\atlassian-jira-gc-%t.log
12-Apr-2021 12:09:20.608 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseGCLogFileRotation
12-Apr-2021 12:09:20.608 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:NumberOfGCLogFiles=5
12-Apr-2021 12:09:20.608 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:GCLogFileSize=20M
12-Apr-2021 12:09:20.608 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCDetails
12-Apr-2021 12:09:20.608 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCDateStamps
12-Apr-2021 12:09:20.623 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCTimeStamps
12-Apr-2021 12:09:20.623 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCCause
12-Apr-2021 12:09:20.624 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+ExplicitGCInvokesConcurrent
12-Apr-2021 12:09:20.625 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
12-Apr-2021 12:09:20.625 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:09:20.627 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:09:20.627 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Users\Arun Raj\Atlassian\Jira\temp
12-Apr-2021 12:09:20.629 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx512m
12-Apr-2021 12:09:20.630 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [C:\Users\Arun Raj\Atlassian\Jira\jre\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;c:\users\arunra~1\appdata\local\temp\e4j4426.tmp_dir1618209046\jre\bin;C:\Users\ARUNRA~1\AppData\Local\Temp\e4j4426.tmp_dir1618209046\user;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Java\jdk-11.0.4\bin;C:\Program Files\Zulu\zulu-13\bin\;C:\Program Files\Git\cmd;C:\Users\Arun Raj\AppData\Local\Microsoft\WindowsApps;C:\Program Files\Java\jdk1.8.0_191\bin;C:\Program Files\Java\jre1.8.0_191\bin;C:\Program Files\Salesforce CLI\bin;C:\Program Files\TestProject Agent;.]
12-Apr-2021 12:09:20.810 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:09:20.831 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1152 ms
12-Apr-2021 12:09:20.861 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
12-Apr-2021 12:09:20.861 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.57
12-Apr-2021 12:09:36.477 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:09:36.510 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
12-Apr-2021 12:09:36.549 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 15702 ms
12-Apr-2021 12:32:29.757 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/8.5.57
12-Apr-2021 12:32:29.760 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Jun 30 2020 21:49:10 UTC
12-Apr-2021 12:32:29.760 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 8.5.57.0
12-Apr-2021 12:32:29.761 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 10
12-Apr-2021 12:32:29.761 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
12-Apr-2021 12:32:29.762 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
12-Apr-2021 12:32:29.762 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Users\Arun Raj\Atlassian\Jira\jre
12-Apr-2021 12:32:29.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_275-b01
12-Apr-2021 12:32:29.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: AdoptOpenJDK
12-Apr-2021 12:32:29.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:32:29.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:32:29.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Users\Arun Raj\Atlassian\Jira\conf\logging.properties
12-Apr-2021 12:32:29.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
12-Apr-2021 12:32:29.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms384m
12-Apr-2021 12:32:29.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
12-Apr-2021 12:32:29.769 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialCodeCacheSize=32m
12-Apr-2021 12:32:29.769 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:ReservedCodeCacheSize=512m
12-Apr-2021 12:32:29.771 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
12-Apr-2021 12:32:29.772 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.standalone=JIRA
12-Apr-2021 12:32:29.774 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true
12-Apr-2021 12:32:29.774 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dmail.mime.decodeparameters=true
12-Apr-2021 12:32:29.780 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory
12-Apr-2021 12:32:29.780 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:-OmitStackTraceInFastThrow
12-Apr-2021 12:32:29.782 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.locale.providers=COMPAT
12-Apr-2021 12:32:29.783 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms384m
12-Apr-2021 12:32:29.783 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
12-Apr-2021 12:32:29.785 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialCodeCacheSize=32m
12-Apr-2021 12:32:29.787 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:ReservedCodeCacheSize=512m
12-Apr-2021 12:32:29.787 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
12-Apr-2021 12:32:29.790 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.standalone=JIRA
12-Apr-2021 12:32:29.792 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true
12-Apr-2021 12:32:29.793 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dmail.mime.decodeparameters=true
12-Apr-2021 12:32:29.793 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory
12-Apr-2021 12:32:29.794 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:-OmitStackTraceInFastThrow
12-Apr-2021 12:32:29.795 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.locale.providers=COMPAT
12-Apr-2021 12:32:29.796 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.plugins.startup.options=
12-Apr-2021 12:32:29.797 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
12-Apr-2021 12:32:29.798 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
12-Apr-2021 12:32:29.799 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xloggc:C:\Users\ARUNRA~1\ATLASS~1\Jira\bin\..\logs\atlassian-jira-gc-%t.log
12-Apr-2021 12:32:29.799 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseGCLogFileRotation
12-Apr-2021 12:32:29.800 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:NumberOfGCLogFiles=5
12-Apr-2021 12:32:29.801 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:GCLogFileSize=20M
12-Apr-2021 12:32:29.802 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCDetails
12-Apr-2021 12:32:29.803 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCDateStamps
12-Apr-2021 12:32:29.807 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCTimeStamps
12-Apr-2021 12:32:29.808 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCCause
12-Apr-2021 12:32:29.809 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+ExplicitGCInvokesConcurrent
12-Apr-2021 12:32:29.810 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
12-Apr-2021 12:32:29.810 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:32:29.811 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:32:29.812 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Users\Arun Raj\Atlassian\Jira\temp
12-Apr-2021 12:32:29.812 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx512m
12-Apr-2021 12:32:29.813 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded Apache Tomcat Native library [1.2.24] using APR version [1.7.0].
12-Apr-2021 12:32:29.814 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
12-Apr-2021 12:32:29.814 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR/OpenSSL configuration: useAprConnector [false], useOpenSSL [true]
12-Apr-2021 12:32:29.826 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized [OpenSSL 1.1.1g 21 Apr 2020]
12-Apr-2021 12:32:30.017 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:32:30.049 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1122 ms
12-Apr-2021 12:32:30.060 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
12-Apr-2021 12:32:30.075 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.57
12-Apr-2021 12:32:44.247 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:32:44.265 SEVERE [main] org.apache.catalina.core.StandardService.startInternal Failed to start connector [Connector[HTTP/1.1-8085]]
org.apache.catalina.LifecycleException: Protocol handler start failed
at org.apache.catalina.connector.Connector.startInternal(Connector.java:1102)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:440)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:766)
at org.apache.catalina.startup.Catalina.start(Catalina.java:688)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:342)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:473)
Caused by: java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Net.java:461)
at sun.nio.ch.Net.bind(Net.java:453)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:222)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:85)
at org.apache.tomcat.util.net.NioEndpoint.bind(NioEndpoint.java:221)
at org.apache.tomcat.util.net.AbstractEndpoint.start(AbstractEndpoint.java:1191)
at org.apache.coyote.AbstractProtocol.start(AbstractProtocol.java:597)
at org.apache.catalina.connector.Connector.startInternal(Connector.java:1100)
... 12 more
12-Apr-2021 12:32:44.271 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 14219 ms
12-Apr-2021 12:32:44.279 SEVERE [main] org.apache.catalina.core.StandardServer.await StandardServer.await: create[localhost:8005]:
java.net.BindException: Address already in use: JVM_Bind
at java.net.DualStackPlainSocketImpl.bind0(Native Method)
at java.net.DualStackPlainSocketImpl.socketBind(DualStackPlainSocketImpl.java:106)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:387)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:190)
at java.net.ServerSocket.bind(ServerSocket.java:390)
at java.net.ServerSocket.<init>(ServerSocket.java:252)
at org.apache.catalina.core.StandardServer.await(StandardServer.java:421)
at org.apache.catalina.startup.Catalina.await(Catalina.java:776)
at org.apache.catalina.startup.Catalina.start(Catalina.java:722)
12-Apr-2021 12:32:44.283 INFO [main] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:32:44.283 INFO [main] org.apache.catalina.core.StandardService.stopInternal Stopping service [Catalina]
12-Apr-2021 12:32:45.071 INFO [main] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:32:45.072 INFO [main] org.apache.coyote.AbstractProtocol.destroy Destroying ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:34:11.714 INFO [main] org.apache.catalina.core.StandardServer.await A valid shutdown command was received via the shutdown port. Stopping the Server instance.
12-Apr-2021 12:34:11.717 INFO [main] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:34:12.058 INFO [main] org.apache.catalina.core.StandardService.stopInternal Stopping service [Catalina]
12-Apr-2021 12:34:12.256 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@14f65c1a]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.276 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [org.picocontainer.DefaultPicoContainer.IntoThreadLocal] (value [org.picocontainer.DefaultPicoContainer$IntoThreadLocal@139999c6]) and a value of type [java.lang.Class] (value [class org.picocontainer.ComponentAdapter$NOTHING]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.276 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@7e67c7e0]) and a value of type [com.atlassian.core.xml.InterningDocumentFactory] (value [com.atlassian.core.xml.InterningDocumentFactory@643b3a78]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.277 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@5c92df0d]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.278 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [org.picocontainer.DefaultPicoContainer.IntoThreadLocal] (value [org.picocontainer.DefaultPicoContainer$IntoThreadLocal@139999c6]) and a value of type [java.lang.Class] (value [class org.picocontainer.ComponentAdapter$NOTHING]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.279 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@31a3af0]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.280 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@4302a5b4]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.281 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@7ed7bf56]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.282 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@34f76d36]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.284 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@66e81ce2]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.285 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@737f1ec5]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.286 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@7c6e5341]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.287 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@5ac74f22]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.291 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@633bdbae]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.293 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@6839683a]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.293 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@6643da27]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.294 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@69d3792]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.295 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@3bc67a44]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.296 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@189dadbe]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.297 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@6077ce68]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.298 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@fb95453]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.299 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@7251bba]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.300 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@72a0a6bd]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.301 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@2cfa320f]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.301 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@6924f00f]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.303 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@4673ce5a]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.308 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@31110d67]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.309 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@360215d2]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@4c062b00]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
12-Apr-2021 12:34:12.312 INFO [main] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:34:12.329 INFO [main] org.apache.coyote.AbstractProtocol.destroy Destroying ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:36:17.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/8.5.57
12-Apr-2021 12:36:17.950 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Jun 30 2020 21:49:10 UTC
12-Apr-2021 12:36:17.950 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 8.5.57.0
12-Apr-2021 12:36:17.951 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 10
12-Apr-2021 12:36:17.951 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
12-Apr-2021 12:36:17.952 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
12-Apr-2021 12:36:17.961 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Users\Arun Raj\Atlassian\Jira\jre
12-Apr-2021 12:36:17.962 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_275-b01
12-Apr-2021 12:36:17.962 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: AdoptOpenJDK
12-Apr-2021 12:36:17.963 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:36:17.965 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:36:17.967 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Users\Arun Raj\Atlassian\Jira\conf\logging.properties
12-Apr-2021 12:36:17.968 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
12-Apr-2021 12:36:17.968 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms384m
12-Apr-2021 12:36:17.969 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
12-Apr-2021 12:36:17.969 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialCodeCacheSize=32m
12-Apr-2021 12:36:17.970 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:ReservedCodeCacheSize=512m
12-Apr-2021 12:36:17.970 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
12-Apr-2021 12:36:17.970 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.standalone=JIRA
12-Apr-2021 12:36:17.970 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true
12-Apr-2021 12:36:17.970 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dmail.mime.decodeparameters=true
12-Apr-2021 12:36:17.976 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory
12-Apr-2021 12:36:17.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:-OmitStackTraceInFastThrow
12-Apr-2021 12:36:17.985 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.locale.providers=COMPAT
12-Apr-2021 12:36:17.986 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms384m
12-Apr-2021 12:36:17.987 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
12-Apr-2021 12:36:17.988 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialCodeCacheSize=32m
12-Apr-2021 12:36:17.990 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:ReservedCodeCacheSize=512m
12-Apr-2021 12:36:17.990 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
12-Apr-2021 12:36:17.991 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.standalone=JIRA
12-Apr-2021 12:36:17.992 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true
12-Apr-2021 12:36:17.992 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dmail.mime.decodeparameters=true
12-Apr-2021 12:36:17.996 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory
12-Apr-2021 12:36:18.001 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:-OmitStackTraceInFastThrow
12-Apr-2021 12:36:18.002 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.locale.providers=COMPAT
12-Apr-2021 12:36:18.002 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.plugins.startup.options=
12-Apr-2021 12:36:18.006 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
12-Apr-2021 12:36:18.007 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
12-Apr-2021 12:36:18.008 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xloggc:C:\Users\ARUNRA~1\ATLASS~1\Jira\bin\..\logs\atlassian-jira-gc-%t.log
12-Apr-2021 12:36:18.009 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseGCLogFileRotation
12-Apr-2021 12:36:18.009 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:NumberOfGCLogFiles=5
12-Apr-2021 12:36:18.015 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:GCLogFileSize=20M
12-Apr-2021 12:36:18.017 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCDetails
12-Apr-2021 12:36:18.018 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCDateStamps
12-Apr-2021 12:36:18.018 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCTimeStamps
12-Apr-2021 12:36:18.018 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCCause
12-Apr-2021 12:36:18.018 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+ExplicitGCInvokesConcurrent
12-Apr-2021 12:36:18.021 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
12-Apr-2021 12:36:18.022 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:36:18.025 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Users\Arun Raj\Atlassian\Jira
12-Apr-2021 12:36:18.026 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Users\Arun Raj\Atlassian\Jira\temp
12-Apr-2021 12:36:18.027 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx512m
12-Apr-2021 12:36:18.028 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded Apache Tomcat Native library [1.2.24] using APR version [1.7.0].
12-Apr-2021 12:36:18.029 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
12-Apr-2021 12:36:18.031 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR/OpenSSL configuration: useAprConnector [false], useOpenSSL [true]
12-Apr-2021 12:36:18.041 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized [OpenSSL 1.1.1g 21 Apr 2020]
12-Apr-2021 12:36:18.267 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:36:18.302 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1329 ms
12-Apr-2021 12:36:18.320 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
12-Apr-2021 12:36:18.320 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.57
12-Apr-2021 12:36:34.868 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8085"]
12-Apr-2021 12:36:34.899 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
12-Apr-2021 12:36:34.924 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 16619 ms
OK.
How to check RAM on Windows:
You can try to check another Atlassian log file: <Jira-install-folder> /logs/catalina.out
Thanks, I don't see a proper ERROR or WARNING in the log file. It might be worth trying to restart the whole server.
When using Windows Server, I wondered what settings file you used JVM_MINIMUM_MEMORY = and JVM_MAXIMUM_MEMORY =? setenv.sh / setenv.bat file?
If you have Jira installed as a service, you need to make the following adjustment Setting properties and options on startup (please find section Windows service)
Oh, thanks for the info. I recommend installing Jira as a service and making settings. I have no experience with configuring a .bat file.
Hai @Pavel Junek i have a another doubt can we use jira cloud credential in jira software(localhost),whether it will fetch all projects in my cloud?
A Jira Server and a Jira Cloud instance are two separate systems with separate data sets.
A Jira Server will not contain copies of a Jira Cloud system's data unless you have set up some form of synchronisation between them, and they will only use the same accounts to log in if you have set them up to use the same user directories
I do not understand what you are asking.
If you want to have issues duplicated in two instances, you probably want to keep them updated with changes made in each system.
