jql query
Loretta June 24, 2020
I am trying to get issues for a project that have child issues instead of bugs.  What do I need to do to get this?  I think it may be a jql query, but not sure and what the query would be.
2 accepted
Jack Nolddor _Sweet Bananas_
Sadly you cannot achieve the desired search using standard features on Jira, you must go for a third-party app instead. If you are on Server/DetaCenter, using i.e. JQL Booster Pack you can type the following:
1) Search for issue on project 'MyProject' having subtasks:
project = MyProject AND issue IN hasSubtasks()
(*) Note that this is just an example, you must tune above query to fit your needs.
Using this app you can also query other issues relations, check:
References:
Kind Regards
June 24, 2020
Hi @Loretta
You cannot do this with out-of-the-box JIRA.  The closest you can get is to list the items and sort by the ones which have subtasks (you cannot search the subtasks field):
project = myproject ORDER BY subtasks
If you have any of the add-on marketplace scripting tools, you can build a query to do what you want.
Best regards,
Ziad Bakhiet
October 13, 2020 edited
Hello Loretta,
You can get the result using JQL Search Extensions
You can search for issues that have subtasks with a particular issue type.
  • JIRA Cloud: subtaskIssueType = "YourSubtaskName"
  • JIRA Server: issue in subTaskType("YourSubtaskName")
There are many other functions related to subtasks like:
The full documentation can be found here.
Ziad
