Hello dears
I am using Automation to sync comments in linked Issus's.
unfortunately i have limitations only 1500 Executions, it is not enough. please tell me the other plugin name i am ready to buy.
the 1500 is the service limit, because it runs 1500 times per a specific time?
you could copy your rule and add a jql filter per issue type to reduce the maximum issues number.
1 rule per issue type could be under the 1500 service limit.
thanks for reply....yes the limit is one month.
no it is not solution for me i need all issue types....please tell me third party plugin if you know my dear :)
you will still have all issue types
--> just 1 rule per issue type instead of 1 rule for all
this will split up the service limit per rule and you can use automation
https://support.atlassian.com/jira-software-cloud/docs/what-are-service-limits/
other addons could be scriptrunner, but I don't use it.
