I am trying to search for issues and order by priority.
ORDER BY priority DESC
but when i do they get ordered but not by priority.
The way they are ordered is:
How can i order them so that they are ordered by [what i perceive to be the correct order]:
thanks.
Can you please check the Priorities admin menu? If you're a Jira admin, you can see it here: https://your-cloud-site.atlassian.net/secure/admin/ViewPriorities.jspa
You can see that priorities are ordered with the most important one at the top and the least important one in the bottom. You can re-order priorities using arrows:
Hope this helps!
- Manon
