originalestimate Jira app
Ivan Andrieiev
Is it possible to create a field "originalestimate" field through the Jira app? Because of IOS, there is an error, and on Android, the field is not active at all.
Nic Brough -Adaptavist-
December 1, 2022
Jira has originalestimate built into it.  It's not a field you can add.
Ivan Andrieiev
@Nic Brough -Adaptavist-  Hi
But tracking can be noted. Is that what it was meant to be?
December 1, 2022
I am sorry, I do not understand that question.
Jira has a "time tracking" function which looks like several fields, one of which is "original estimate".  You can't add duplicate fields of system field like that.
Ivan Andrieiev
There is a Jira application, tasks are displayed there, we can insert tracking, but not the original estimate.
December 1, 2022
What do you mean by "insert"?  You said earlier that you were trying to add a field, but do you mean you are trying to add data to a field, not add a field?
What do you mean by "tracking"?  Does it let you add work logs, estimates and so on?  Or something else?
Ivan Andrieiev
Does it allow you to set an original time estimate?
December 2, 2022
Yes, I can set the original estimate.
Ivan Andrieiev
Can you do these things through the app?
December 7, 2022
As I said already.
