post function status condition
valkyre57
i am trying to add assignee when condition is status "trtrtrtr". the test passes well but assignee not working.... what i am doing wrong?
Suprija Sirikonda _Appfire_
May 18, 2021
Hi @valkyre57 ,
Note that all the clauses must be inside a single {{ }} block :
And, of course, the user executing the post-function must have assign issues permission.
Suprija
valkyre57
i tried single block too. user has permissions.
May 18, 2021
Hi @valkyre57 ,
Did you test without the Conditional Executional script? - i.e., is the Assignee being set correctly without the conditional execution script?
As you are checking for the status of the issue - note that the issue's status will be either the Status before the transition or the Status after the transition - as post-functions in cloud run asynchronously
If you want to check the destination status : use transition.to_status
{{ issue.fields.issuetype.name == "Bug" and transition.to_status == "rtrtrtrtr" }}
Else, if you want to check the source status : use transition.from_status
{{ issue.fields.issuetype.name == "Bug" and transition.from_status == "rtrtrtrtr" }}
Suprija
valkyre57
transition.to_status WORKED
thanks a loooot !
May 19, 2021
Hi @valkyre57 ,
I'm glad it worked! Please feel free to accept my answer if it helped you.
Suprija
Max Foerster - K15t
Hey @valkyre57 ,
have you checked that the user is available as an assignee (assignable user project permission) and if the executing user of the post function is also able to assign the issue? You should also be able to troubleshoot this with the help of the status and log page of the app. :)
Best, Max
John Funk
Hi @valkyre57  - Why don't you just use an Automation for Jira rule to set the assignee based on those conditions?
valkyre57
it is limited :( and that why i am trying to create post function.
John Funk
It will do what you are tying to do in this case  :-)
Like • Max Foerster - K15t likes this
Register today
