"Copy Labels from Epic issue" really a replace/sync ?
bmacd
I recently set it up automation to copy labels from an epic to its child stories and tasks using two triggers (mainly to capture any Jiras in progress - see screenshot) and what I've discovered is "Copy Labels from Epic issue" doesn't seem to be a copy but a replace/sync - ie. when triggered the labels are copied from the epic, BUT if i then add additional labels to a story when the automation is triggered again it removes those additional labels.
Any ideas on how i can copy labels from the epic and keep additional labels in place?
4 votes
Alex Koxaras _Relational_
Hi @bmacd
Try to check the following option:
bmacd
That looks like it worked - thanks!
Like • Alex Koxaras _Relational_ likes this
Jeroen Poismans
Hi there!
You are almost there :-).
If you click the 3 dots in the Edit Issue action you can select ADDREMOVE:
Screenshot 2023-03-20 at 07.47.14.png |
Then, in the Values to add box you can again select Copy from Epic:
This way, the labels you added manually won't be overwritten in the next trigger.
Hope this helps!
Jeroen
bmacd
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
