"Create a branch in bitbucket" action in automation does not list all repositories
nils.heissner
January 11, 2023
i am trying to create an automation-rule in a jira-software project. I want the rule to create a branch in a bitbucket cloud repository.
While creation of the "create branch in bitbucket" action, i can successfully select the correct bitbucket workspace and connect to it.
My problem is, that the repository dropdown-list does not show all the repositories in the workspace.
I was not able to determine a difference in settings between the repositories that do show up and the ones that dont.
Any suggestions and hints are appreciated.
Trudy Claspill
Hello @nils.heissner
Welcome to the community.
How many repositories are there?
Have you tried typing in the name of the missing repo to see if it finds a match?
Do you have permission to create branches in the missing repos?
nils.heissner
January 12, 2023
Hello @Trudy Claspill
thank you very much for the quick answer.
"Have you tried typing in the name of the missing repo to see if it finds a match?"
Not until you mentioned it. By typing the name i was able to find the repository i wanted.
I did not even thought about typing the name in, the dropdown list did not appeared to be writable on the first look.
FREE
