removing fields from this screen
Larry Vervynckt November 7, 2023 edited
Good Morning,  I can not figure out how to remove fields from the screen in the screenshot.  I appreciate any help I can get.  Larry
Sanjen Bariki
November 7, 2023
Hi @Larry Vervynckt ,
Welcome to Atlassian community!
Please go into the associated project setting >> summary >> screen >> screen configuration >> create screen >> In the create screen remove the field. Please follow the below link to remove the field from screen.
If you need kindly connect with Jira Admin to do this activity.
Please accept the answer If it helps you😊
Sanjen
Joe Pitt
Fields are put on the screen when the screen is configured or when the field is added. The Jira admin can remove the field from the screen.
Register today
