script runner post function create subtask: how to block link creation?
Aspect Infra Team
September 1, 2013
then i create subtask in postfunction with "create subtask" built-in scripts of script-runner plugin it copy all fileds to subtask
i found already how to overrive most of fields the only problem persist
i need to block coping of links from parent issue
issue.issuelink = null
doesnt work, how i can block link creation?
Alex Corsun September 10, 2014
You can try adding " checkLink = {link -> false}; " in additional issue actions - it will delete additional parent links (but still keep standard sub-task link to a parent issue).
