show releasedate in filter result
JvN February 19, 2025
Is it possible to show the "Release date" from releases in a filter? I can't find it in the field selection.
3 votes
Fabio Racobaldo _Herzum_
Hi @JvN and welcome,
release date is something associated to version and not directly to a ticket so, for my knowledge, you can't add release date as column in a filter.
Fabio
JvN February 20, 2025
Thanks for your answer. Did you mean I can't add a column with that information? If I can add it, how do I do that?
sorry @JvN , you can't add it in a filter result.
I have found a workaround:
Create an Automation rule that sets a date field on the issue with the Releasedate when the Version is released.
Than you can use that field in the filter view.
