show subtask hours in view issue screen
Yen Pham
From within the view issue screen (i.e. https://liveops.atlassian.net/browse/xxx-yyy) can you make the sub tasks show the remaining estimates in numbers without hovering over the graphical bar?
Karalee Kikiros
December 8, 2016
Hi Yen. You can edit the jira.table.cols.subtasks in your JIRA Admin > System | General Setings > Advanced Settings to show Remaining Estimate as well or instead of Progress. If you have not done this before though, I strongly suggest that you change it in your sandbox instance before playing around with it in your actual instance
Yen Pham
Hi Karalee - thanks for that; do you know what the value name is for remaining estimate?
Karalee Kikiros
December 13, 2016
It should be remainingEstimate
Stefan Zerjatke
September 22, 2017
The value "timeestimate" worked for me.
For orginal estimate use "timeoriginalestimate".
