subtask validation from parent's field used JMWE
Tyas Iglecias
February 5, 2021 edited
Hi guys,
I have 3 field :
1.  Vendor (A) : Text Field (multi-line) 12038
2.  Developer (B) : User Picker (multiple users) 12443
3.  SQA (C) : User Picker (multiple users) 12444
fields will be filled in Parent workflow,
I will make validation in sub-task used Linked Issues Validator (JMWE app)
Status Movement from open to in progress if :
A Empty + B Empty +C Empty= stop
A Empty + B filled +C Filled = move
A filled + B filled +C Filled = move
A filled + B Empty +C Empty = move
but I try my script and the result not same with my needs
(linkedIssue.customfield_12038 == null && linkedIssue.customfield_12443.length == 0 && linkedIssue.customfield_12444.length == 0)
(linkedIssue.customfield_12038 == null && linkedIssue.customfield_12443.length > 0 && linkedIssue.customfield_12444.length > 0)
(linkedIssue.customfield_12038 != null && linkedIssue.customfield_12443.length > 0 && linkedIssue.customfield_12444.length > 0)
(linkedIssue.customfield_12038 != null && linkedIssue.customfield_12443.length == 0 && linkedIssue.customfield_12444.length == 0)
the result  :
A filled + B Empty +C Empty = stop
please help me for corrections related to what i have made
Tyas
David Fischer
Apparently, Jira expressions return "" for an empty multi-line text field (instead of null). Therefore, the script should be:
(!linkedIssue.customfield_12038 && linkedIssue.customfield_12443 != null && linkedIssue.customfield_12444 != null)
(!!linkedIssue.customfield_12038 && linkedIssue.customfield_12443 != null && linkedIssue.customfield_12444 != null)
(!!linkedIssue.customfield_12038 && linkedIssue.customfield_12443 == null && linkedIssue.customfield_12444 == null)
Tyas Iglecias
Hi @David Fischer ,
After used your script, result is :
A Empty + B Empty +C Empty= move
Are there any settings I missed?
David Fischer
Hi @Tyas Iglecias ,
that's probably because, when a multi-user picker field is empty, it doesn't return an empty list but null. Therefore, you should not test the length against 0 but the field against null. Also, your first test is incorrect, since it will pass if all 3 fields are empty. Generally, you need to think in terms of every case where the validator should pass.
(linkedIssue.customfield_12038 == null && linkedIssue.customfield_12443 != null && linkedIssue.customfield_12444 != null)
(linkedIssue.customfield_12038 != null && linkedIssue.customfield_12443 != null && linkedIssue.customfield_12444 != null)
(linkedIssue.customfield_12038 != null && linkedIssue.customfield_12443 == null && linkedIssue.customfield_12444 == null)
