transition screen
Ivan Andrieiev
after adding the transition screen it doesn't work. What could be the reason?
Dirk Ronsmans
@Ivan Andrieiev ,
Could you explain it a bit more in detail?
What exactly are you attempting to do and what do you mean by "it doesn't work"?
Ivan Andrieiev
@Dirk Ronsmans  Hi
I set the transition screen to have the status "to do" and "in progress", but nothing happens when the status changes, maybe you still need to adjust the properties of the transition?
Ivan Andrieiev
@Dirk Ronsmans
I did soСнимок экрана 2023-05-09 в 17.16.32.png Снимок экрана 2023-05-09 в 17.16.44.png
Dirk Ronsmans
Did you also publish the workflow?
Ivan Andrieiev
Ivan Andrieiev
I found problem, thank you for your attention.
SKellam September 18, 2023
What was the problem? I am also having an issue getting mine to appear.
