uppercase/lowercase in text formatting notation
Luc Noppen October 8, 2020 edited
In jira automation I use the description field to give some extra info. I'm using smartvalues. But sometimes I want text to be in lowercase/uppercase. At first sight there's nothing available in the Text Formatting Notation.
Or am I mistaking?
Kind regards
Manon Soubies-Camy
Hi @Luc Noppen,
You can find several functions here that should help you, for example:
  • {{issue.summary.toLowerCase()}}
  • {{issue.summary.toUpperCase()}}
Hope this helps,
- Manon
Thanks for your reply.
I think that your suggestions apply to the complete text in the summary field.
I only want some text in upper case or lower case, especially when using smartvalues.
E.g. This is <lower>{{issue.fields.my_custom_field}}</lower> an example.
Or something like that.
Kind regards.
Luc
Sankalp Chugh
In that case you would need to use other Jira function in conjunction with the former function.
See substring or other functions as required here.
Register now
