Jira Automation: Updating a Confluence page with information from Jira issues
This article provides instructions for creating a solution that utilizes Jira Automation and the Confluence REST API to update a Confluence page with information from Jira issues.
For instance, When a label is added to a Jira issue, the label and the issue key should be added to an existing Confluence page.
Solution
The plan is as follows:
  1. Get the page details using the REST API endpoint Get page by id.
  2. Retrieve the page content and the page version.
  3. Update the page using the REST API endpoint  Update page. This Endpoint overwrites the existing page content. Therefore, we needed to retrieve the page content in Step 2.
Get Page ID
  • Use this API endpoint Get pages to get the Confluence page id.
    Or you can get the page id from the Confluence page:
    • Go to the ellipses (...) at the top-right of the page > Advanced Details > Page Information
Get the version number
  • Use this API endpoint Get page by id to get the page version.
  • Use Jira smart values to save the page version.
    {{webResponse.body.version.number}}
Get the page content
  • Use this API endpoint Get page by id and append this parameter ?body-format=storage at the end of the URL to get the page content. Example:
    https://<Cloud URL>/wiki/api/v2/pages/<Page ID>?body-format=storage
  • Use Jira smart values to save the page content.
    {{webResponse.body.body.storage.value}}
Build the automation rule
  1. Add a Field value changed trigger and select the labels field when a value is added.
  2. Add a Send web request to get the page information and add the following information:
    • Web request URL: https://<Cloud URL>/wiki/api/v2/pages/<Page ID>?body-format=storage
    • Method: GET
    • Web request body: Empty
    • Select the checkbox: "Delay execution of subsequent rule actions until we've received a response for this web request"
    • Add the following headers:
      • Accept: application/json
      • Content-Type: application/json
      • Authorization: Basic <encoded Email:APIToken>
  1. Add another Send web request to update the page and add the following information:
    • Method: PUT
    • Web request body: Custom data
        "id": "<Page ID>",  //pageID
        "status": "current",
         "title": "<Page Title>",  //Pagetitle
         "body": {
          "representation": "storage",
          "value": "{{webResponse.body.body.storage.value}}\n{{issue.key}} {{issue.labels}}" //Page current content + new content
        "version": {
          "number": "{{#=}}{{webResponse.body.version.number}} + 1{{/}}"  //Increment page version
34 comments
YY Brother
 Hi @Hala ElRoumy
Thanks for your sharing.
Automation for Jira (A4J) is a Jira App, which was acquired by Atlassian. And the rebradning name is Jira Automaiton, I think.
YY哥
Like Hala ElRoumy likes this
Hala ElRoumy
April 4, 2024
Updated. Thanks @YY Brother
Like YY Brother likes this
vincenzo_spatafora
Hi @Hala ElRoumy, thanks for sharing that.
What about the case where you need to edit/update (PUT) a specific cell of a table which is in Confluence?
See please attached file showing the table where I would like my automation rule is update the status of the JIra tickets (as their transition changes).
Thanks in advance, Vincenzo.
vincenzo_spatafora
Hi @YY Brother, thanks for that.
See please attached file showing the table where I would like my Jira automation rule to update the status of the JIra tickets (as their transition changes).
I use Jira DC version 9.12.5.
YY Brother
Hi @vincenzo_spatafora
About jira issue status update in confluence page, if you insert jira issue macro into the page, the jira issues' status will change accordingly in the confluence page (refresh) once jira issue's status is transitioned.
I don't for your scenario, it seems we don't need automation.
Like vincenzo_spatafora likes this
vincenzo_spatafora
Thank You @YY Brother, thanks for your comment.
Kind Regards, Vincenzo.
vincenzo_spatafora
And @YY Brother
would you know the syntax to add 2 (or 3) issues key in the confluence macro?
I have tried the follwoing but it doesn't work; it picks alwasy the first issue key.
YY Brother
key in (xx,  xx)
vincenzo_spatafora
Thank You very much @YY Brother , very appreciated.
Anthony Nguyen
Doesn't work for me, unfortunately.
Sending {{webResponse.body.body.storage.value}} back in during step 3 causes error for me if it is anything other than simple text.
Resolved:
https://community.atlassian.com/t5/Confluence-questions/Web-Request-GET-Get-Page-into-PUT-Update-Page-is-not-working/qaq-p/2728904
YY Brother
duplicated body? {{webResponse.body.body.storage.value}}
Please show us your payload so that we can identify how to write it
Anthony Nguyen
Thank you, I figured out the mistake. If {{...value}} contains any elements like smart link, the unescaped " in them causes an issue when trying to use it again for update. I believe I resolved it by doing {{...value.replace("\"", "\\\"")}}. I'll add a link to my question to my original comment.
Just use jsonEncode.
vincenzo_spatafora
Hi @Anthony Nguyen,
how have you managed the Authorization Basic part?
I get Error 401.
Thanks, Vincenzo.
Carl Pritchett
For 401, you need to ensure you are using the Authorization header with the value
Basic <base64 encoded email_Address:api-key>
See this article https://developer.atlassian.com/cloud/confluence/basic-auth-for-rest-apis/
Like # people like this
Juan D’Achiardi
August 5, 2024
@Hala ElRoumy thank you so much for sharing this. It's exactly what I need. However, I am getting a 404 response on the web requests. What I am doing in my automation is:
Trigger:
  • When a version is released
Actions:
  • Transition issues tagged with that fixVersion to Deployed
  • Create a page in Confluence
  • Store a variable with the created page id {{pageId}}
  • Log the {{pageId}} variable
  • Using the stored value, retrieve the content of the created page via the confluence API
    • GET | https://<ourcompany>.atlassian.net/wiki/api/v2/pages/{{pageId}}?body-format=storage
  • Store a variable with the part of the response that I need {{content}}
  • Modify the {{content}} and store as {{updatedContent}}
  • Using the new value, update the page
    • PUT | https://<ourcompany>.atlassian.net/wiki/api/v2/pages/{{pageId}} with custom data in the request body
Unfortunately, for both the requests GET and PUT, I am getting 404s. When I try to run manually on terminal or postman, it works fine.
Do you have any ideas or can you see what I am doing wrong?
Hala ElRoumy
August 5, 2024
Hi @Juan D’Achiardi , You are welcome. I'm glad the post was helpful.
If you are creating a new page and not updating an existing one, you can just use the Create page endpoint and add the content you want to the page body in the same request.
Example:
Use the API endpoint Create page with the following configuration:
Web request URL: https://<Site Cloud URL>/wiki/api/v2/pages
HTTP method: POST
Custom data:
  "spaceId": "<SPACEID from Confluence>",
  "title": "<Title has to be unique>",
  "body": {
    "value": "<The content you want>"
How to get the space ID?
Run this API in the browser:
https://<Site Cloud URL>/wiki/rest/api/space/<SPACE KEY>
Can you please try it out and share a screenshot of the rule? Thanks!
Ella Z
August 16, 2024
never mind! i found the solution.
Hala ElRoumy
August 16, 2024
@Ella Z If there's anything else, let me know ;)
Jason M.
@Ella Z Could I perhaps trouble you for any additional details regarding the solution found, on that fateful day of August 16th?
Kim Serradell
February 5, 2025
Hello
I've been able to make the example work but the content of the page is only showing the issue key (which is useless for me).
If I try to add the description of the issue to the Confluence page like this:
   "body": {
    "value": "{{webResponse.body.body.storage.value}}\n{{issue.description}} {{issue.labels}}" //Page current content + new content
  "version": {
 Then I have an error:
Error found in the HTTP body response:
{"errors":[{"status":400,"code":"INVALID_MESSAGE","title":"Invalid message","detail":null}]}
What am I doing wrong?
Any help would be appreciated.
KiM
February 5, 2025
Hi @Kim Serradell -- Welcome to the Atlassian Community!
First thing, this is a very old article / thread, so it may help to create a new question and perhaps add a link back to the article.  That will ensure the maximum number of people see it to offer suggestions.
Until that new question is created...
Depending upon the contents of your Description field, it may be producing an invalid JSON expression.  Perhaps try adding encoding to the field to help:
{{issue.description.jsonEncode}}
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/#Json-encoding
Chris.Parkes
This is super useful - great document and thanks for sharing!
Kim Serradell
February 6, 2025
Thanks for your input @Bill Sheboy
Unfortunately, I did not work.
I will try to reach Atlassian Support.
Hala ElRoumy
February 6, 2025
Hi @Kim Serradell, I'm happy to see you found this article helpful.
I see Bill has already suggested a good solution. To look further into the rule and help debug it, please contact our support and I would be happy to assist you!
Hala
Hala ElRoumy
February 6, 2025
Thank you @Chris.Parkes for your feedback! I'm happy that you found it useful! :)
Like Chris.Parkes likes this
