New automation triggers across Jira Cloud, Bitbucket, GitLab & Github!
84 comments
Will Lu
Thanks @Shilpa Airi , it worked!
@John McKiernan so far it's working great.  I added triggers on branch creation, commit, and pull request creation and they all worked as expected.  My use case is to move a ticket into in progress when there's obvious work being done on it via git activity and devs forget to update jira from backlog or to do status.  One improvement I would make is to allow multiple triggers in the same rule.  Right now I created 3 rules and the only difference between the rules is the trigger.
Thank you so much for getting this out.  My team will be excited to see this in action.
Like 4 people like this
John McKiernan
May 13, 2020
Nice! Delighted it is working for you @Will Lu and thanks for sending through how you are using these new triggers. The engineers put a lot of work into bringing it to life so it is always nice to share feedback and show how it helps customers :)
Best of luck and give a shout if you run into any trouble!
Lars Hansen
May 14, 2020
Things seem to be working on our side as well.
Only two triggers so far, and some errors on transitioning, but the triggers seem to be working thus far.
Thank you very much for this update!
Like Shilpa Airi likes this
Max MacLeod
Hi @John McKiernan this looks really exciting! Any idea when this automation trigger might be available on Jira Server?
Like 3 people like this
LIndsay Kiefer
Hi @John McKiernan would love this feature to be added to  Jira Data Center. Is there a link or issue to vote for this functionality??
Like 2 people like this
John McKiernan
May 18, 2020
Hey @Max MacLeod @LIndsay Kiefer
At the moment, it is only available on Cloud. I will update you when I learn more about the Server/DC roadmap. Hope that works!
John
Wei_Kong
May 19, 2020 edited
@John McKiernan We tested it out by automating our happy path work flow for development. So far after testing just a few tickets, the automation has worked like a charm. I am actually pleasantly surprised on how easy it has been to use this, at least for this primary work flow. It's nice! Thanks for keeping us updated and working on this!
The only problem now is that the development panel has never showed up or worked for us. That's a separate issue though.
John McKiernan
May 19, 2020
Glad to hear it @Wei_Kong ! Nothing better than when something just works :)
Like Wei_Kong likes this
Tim Malone
What happened to the 'pull request approved' trigger? :)
Laurent IOZELLI
June 3, 2020
Can't wait to try it with Gitlab :D
Like Jeremy Bottein likes this
Jeremy Bottein June 4, 2020
Very much looking forward to test that feature out on Gitlab.
How can I get a notification to know when this is available?
John McKiernan
June 4, 2020
Hey @Jeremy Bottein ,
It is available now! You should be able to connect your accounts and get started immediately :)
John
Like Laurent IOZELLI likes this
Guillaume Wolf June 4, 2020
Automations is exactly what Jira needed. Excellent job here.
I would love to see Bitbucket integration work also the other way, in the actions section. Like when a story transitions, automatically create the related branch.
Again great work guys!
Shilpa Airi
June 4, 2020
Hey @Guillaume Wolf ,
Thanks, and we would love to hear more such use cases where you need to trigger automatic actions on Bitbucket.
Shilpa
Terje Røstum June 5, 2020
This looks really awesome and would benefit the different organizations i do consulting work for.
The bitbucket integration is really simple and easy to use, however, i have sometimes run into problems when trying to connect github with jira. I see others have similar issues.
I also notice that you state that you are working on getting this to work with github/gitlab.
Does this mean there will be a new way of integrating jira with github or is the "github for jira" app on market place the solution? Will there be any major changes to that app?
Artur.Cybruch
The rules work great and the delivery teams found many useful use cases for the automation. Thanks for this functionality!
I have a small question about a particular case though:
To give a bit of a background, we're dealing with a monolith application and the teams have 2 scenarios for pull requests being raised and transitioned to Code Review:
  • Only 1 PR in BitBucket is raised against an item and this item should then move to Code Review in JIRA
  • A team member can raise multiple PR and the transition should only happen when the last PR is raised in BitBucket
Are the automation rules capable of handling our 2nd scenario?
Jeremy Bottein June 5, 2020
Hi @John McKiernan , is there a specific way Jira should be integrated to Gitlab for it to work?
My configuration is based off of https://docs.gitlab.com/ee/user/project/integrations/jira.html
But it does not seem to work.  I tried to setup an automation to move a ticket to "Ready for Release" when the merged request is approved.
Maybe I have an issue with the TransitionID setup?
Or is it something else?
Thank you,
Best.
Jeremy
Shilpa Airi
June 8, 2020
Hi @Terje Røstum
Thanks for the feedback. Can you please share the specific issues that you're facing while connecting with GitHub? Meanwhile, please refer to this GitHub for Jira for more details.
We already support GitHub and GitLab, together with Bitbucket. You need to use the 'GitHub for Jira' or "GitLab for Jira" to get the integration going, and then include a Jira issue key your git activity. Hope this helps.
Shilpa
Shilpa Airi
June 10, 2020
Hi @Jeremy Bottein
You might want to follow the guidance here to integrate GitLab with Jira based on the product flavours (self-managed instance or GitLab.com) you're using. You'll need to link your Jira issue with your Git activity by referring to the relevant Jira issue keys.
Please confirm that you're able to see your git activity under the 'Development' section on the Jira issue view. Once that's done, your automation rules should work. Hope this helps. Do let us know how you went with that.
Hannah Kerley June 11, 2020
This is a great feature for our team.
Are there plans to add triggers for things like comments and approvals on a pull request, or being able to assign a Jira issue based on a Pull Request Reviewer or Author?
Shilpa Airi
June 11, 2020 edited
Hi @Hannah Kerley ,
These are interesting suggestions, we'll definitely look into these.
cheers,
Shilpa.
Chris Lewis
June 22, 2020
Is there a way to get the commit message inside the automation rule? Where can I get a list of smart values for this activation?
sowjanya gondi
Hi, there is a comment here that says AWS codecommit is not yet supported and is not in the list. I was wondering if there are any plugins that could help to integrate with AWS codecommit?
Thank you.
Like josh_kirby likes this
Shilpa Airi
June 30, 2020
Hi @sowjanya gondi and @josh_kirby
Quick update on this one. BigBrassBand (https://marketplace.atlassian.com/apps/1219270/dev-info-for-jira?hosting=cloud&tab=overview) marketplace app can be used for integrating AWS CodeCommit with Jira. Hope this helps.
Shilpa
Like Adam Wride likes this
sowjanya gondi
Thanks a lot for the update @Shilpa Airi ! I will give it a try.
