Send a list of issues in Slack with Jira automation’s newest action (Cloud)
53 comments
Tom Williams
July 30, 2020
@Sam Harding Thanks for spotting that! damn capitalisation!!
Like Sam Harding likes this
blemasle July 30, 2020
@Sam Harding You might want to update your doc then, because it says otherwise :)
I didn't even try it because of this :(
https://support.atlassian.com/jira-software-cloud/docs/automation-actions/#Automationactions-Lookupissues
"Use smart values here: No"
Thanks for the heads up!
Sam Harding
July 30, 2020
@blemasle Thanks for pointing that out, we'll fix that up. Sorry for confusion caused here! Cheers
Tom Wilson August 11, 2020
Is there any way to add in formatting?
https://api.slack.com/reference/surfaces/formatting#visual-styles
Trying to bold a specific text and it's not working as expected
*bold*{{version.description}}*bold*
results in this being sent to slack..
*bold*version description here*bold*
Tom Williams
August 11, 2020 edited
Hi @Tom Wilson
it’s *{{version.description}}*
@Tom Williams That worked!  Is there a reference guide for how to format messages to slack?
Tom Wilson August 13, 2020
I can't see to get issueType to display during my automation inside look up values.
here is all the options i tried, but getting empty string when it prints out to slack..
---- [{{issueType.name}}] - [{{issueType}}] -[{{issue.issueType.name}}] -
Anyone else have this problem?
Tom Williams
August 13, 2020
Hey @Tom Wilson
I had the same issue, looks like the documentation is incorrect and it should be {{issuetype}} so to get the name would be {{issuetype.name}}
Michael
I am having a hard time getting this to work as expected. I am sending a daily email with this is the email body:
<ul>
{{#lookupIssues}}
<li>{{key}} - {{summary}}</li>
</ul>
I have tried several variations of  {{#lookupIssues}} } {{/}} but have had no success. For me, I receive multiple emails. For example, if my JQL returns 5 issues, I receive 5 emails. Am I missing something?
Neetu Verma
Michael,
May you please put a screenshot of your rule.
This is how mine is set and I only get one email
{{#lookupIssues}}
| {{url}} | {{key}} | {{status.name}} | {{issuetype.name}} | {{summary}}
Michael
@Neetu Verma
JQL:
project = EZ AND Sprint in openSprints() AND status not in (Open,Done) AND timespent is EMPTY
 Email:
<ul>
{{#lookupIssues}}
</ul>
Tom Williams
October 22, 2020
Hi @Michael ,
Simple fix! You need to move the JQL from the Schedule Trigger and add the "Lookup Issues" action before the email send action.
Like Neetu Verma likes this
Michael
@Tom Williams I’m not sure I understand your solution. Can you give me an example or screenshot?
Tom Williams
October 22, 2020
@Michael here you go.
Michael
@Tom Williams Thank you! This fixed my issues.
I guess I should have paid closer attention to this checkbox "Run a JQL search and execute actions for each issue in the query" haha.
Thanks again.
Like Tom Williams likes this
Neetu Verma
Yep, just move email as an action item
Nofar Ben Kereth
Hey!
You wrote - ". It could also mean commenting, transitioning, or updating every issue in the list. Magic!"
How can edit a field for all issues in the list? I couldn't find a solution that doesn't include Scheduled Trigger. I would like to use it with Manual Trigger or use it as an post action for another rule (for example - after sending the Slack message with the list of issues, change a custom field value for all issues in list).
I can't seem to find a solution anywhere
Jibu Chacko December 14, 2020
@Tom Williams I have used the below JQL
status != Done AND created >= "-7d" AND created <= "-1d" AND NOT status changed
Where I get 4 issues when I validate
I am trying to send the same to slack.
When I use the below
<{{#issues}}{{url}}|{{key}} - {{summary}}{{/}}>
It works fine. I get the URLs printed
But when I use
{{#lookupIssues}}{{key}}{{/}}
Even if I use {{lookupIssues.size}}  it prints 4 blank lines It prints 4 empty lines.
What am I doing wrong here? I am on the Jira Cloud Enterprise version
Deleted user January 20, 2021
Is the {{#lookupIssues}} feature supported on Jira Automation for Server already?
Martin Cleaver
March 8, 2021
 Jun 28, 2020 This new feature is unfortunately only available for the Cloud version of Jira automation right now (as opposed to the Automation for Jira app)
@John McKiernan
  1. When will it be available for DC? I can understand some lag, but June '20 to March '21 is more than a little time for your biggest customers to wait.
  2. What is the workaround?
Thanks, Martin.
Christian Macedo March 12, 2021
Is it possible to filter or perform a group by on the {{#lookupIssues}} list?
I want to send out an email for each release which separates out bugs, stories and tasks. Similar to the below rather than as a single long list.
Bugs:
  • Bug 1
  • Bug 2
Stories:
  • Story 1
  • Story 2
Tasks:
  • Task 1
Like maricris.macha likes this
Darrin Lange March 12, 2021
@Christian, I ended up having separate rules for each group.
Christian Macedo March 12, 2021 edited
@Darrin Lange
Is there no way to get the three groups into a single email?
I'm attempting to figure this out but just can't. The closes I can get to filtering on lookup issues is as below.
<ul>
{{#lookupIssues}}
    {{issuetype.name}} //Just prints it to make sure there's nothing wrong with the list
    {{#if(issuetype.name.equals("Bug"))}}
        <li><a href="{{issue.url}}" target="_blank">{{key}}: {{issuetype.name}} - {{summary}}</a></li>
</ul>
This only prints the issuetype.name from just inside the {{#lookupIssues}} loop. It doesn't seem to enter the #if.
Hi @Christian Macedo , I wasn't able to get that to work either. Instead of using the #if, incorporate your issuetype = Bug into your lookupissues JQL. Then, create a new rule for each issue type you want to push to Slack.
@Darrin Lange That's the issue. I want to have these all grouped in a single email. Not slack.
