Sign up Log in
Atlas - automation for Jira
Lucrezia Mastrototaro
January 19, 2024
Hi Team,
I wanted to find out if it is possible to edit Atlas custom fields using automation for Jira.
For example, if I enter a field in the epic screen of Jira work management and edit that value, whether it can be carried over to the custom field in Atlas.
Specifically if there is a way, by updating Jira epics with fields, to also edit the goals so that team members are kept up to date (by Jira).
Thank you
Kevin Garcia
May 8, 2024
Inactive Stephen
March 2, 2024
Hi @Lucrezia Mastrototaro
Not at this stage I'm afraid, but you could suggest this as a feature?
You can do that from here: https://jira.atlassian.com/secure/Dashboard.jspa
Ste
