Automation Confluence trigger if page or also subpages were changed
Alexander Pappert
July 23, 2024
I want to implement the same automation rule on a confluence page and all its subpages.
But I can only find page related triggers, is it possible to also watch the corresponding subpages?
July 23, 2024 edited
Hi @Alexander Pappert
First thing, I am not using Confluence automation rules currently, and so my suggestions are based on what I recall and find in the documentation.  With that out of the way...
I wonder, could you use a branch on CQL, checking if the parent (or ancestor) is the trigger page?
https://support.atlassian.com/cloud-automation/docs/branches-in-confluence-automation/#For-each-CQL-result--related-entities-
https://developer.atlassian.com/server/confluence/advanced-searching-using-cql/#parent
https://developer.atlassian.com/server/confluence/advanced-searching-using-cql/#ancestor
Alexander Pappert
July 23, 2024
Hi @Bill Sheboy
in jira I sue branches, but the rule trigger is when main issue is changed and then the rule check branches.
I would need a trigger on main page that is also triggered when one of the many child pages was changed, but I couldn't find it yet.
Like • John Funk likes this
July 25, 2024
Thanks for clarifying, and I believe you would need two rules: one triggered on a parent change (which would find children of that parent) and one triggered on a child (which would find siblings through the parent).
John Funk
Hi Alexander - I am not aware of being able to apply that down to the subpages also.
