I am using the automation module to change the Rank of some type of issues:
Looks like I need to use the "Send web request"
Can you help me plz,
Abir
Community moderators have prevented the ability to post new answers.
Hi @Abir Brahem
What problem are you trying to solve by doing this? That is, why do this? Knowing that may help the community suggest additional ideas.
Until we know that...
It is possible to call a REST API function to set the rank of one (or more) issues relative to another issue. And so the rule would need the key for the issue above / below which to re-rank the target issue.
This how-to article describes how to call a REST API function from a rule using the Send Web Request action: https://community.atlassian.com/t5/Jira-Software-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
I recommend contacting your Jira Site Admin before writing this rule as they may provide some additional support.
Hello Bill,
Thank you for the link, now I am able to request the JIRA Cloud API.
I would like to change the rank of some type issues to the top.
I found this end point in the documentation:
The Jira Software Cloud REST API (atlassian.com)
I tested with PostMan and I it is possible to change the rank:
rest/agile/1.0/issue/rank
request body:
Have you discussed this scenario with your Jira admin yet? I recommend doing that before you proceed further, as you have not explained the problem you are trying to solve and the conversation with your admin may help.
For example, you do not describe why or when this change of rank is needed, and those impact the rule trigger and issue context for making changes.
Regarding the rule specifics, as you have already successfully called the REST API function with PostMan and you have the how-to article for calling the function from a rule, you can use that request body as a template in your Send Web Request action.
I am a JIRA admin, unfortunately there no expert more then me in the company.
The trigger is when issue created and if issueType is Bug (I can't add screenshot, I don't now why..)
I can't use the send Web Request because I need the highest issue key as I descibe in my last message.
Is that clear?
Let's assume this is for one project and you only care about issues in the backlog. To find the issue which is currently the highest-ranked one, JQL may be used:
project = yourProjectName AND status = Backlog ORDER BY Rank ASC
The first one in the list is the highest-ranked issue.
Thus a rule could use the Lookup Issues action with that JQL to gather the first 100 issues found, and the first in the list would be the key needed for the request:
{{lookupIssues.first.key}}
Hi @Bill Sheboy and @Abir Brahem I'm trying to achieve something similar. Reason being is that when issues are created by any one of the 20 members in the team they can be lost in the backlog.
So I want a rule that that runs once a week to find any issues marked as Security and or Compliance (custom field) and move them to the top of the backlog so that when we do sprint planning those items are always first.
Does that help with the Why?
Hi Bill, Thank so much, I succesfully update the Rank finally !
@Brendan Betheldo you request is a little bit more complicated: you can Inspired by my rule (see below). First of all, to change the trigger to Scheduled and you need to change the web request body to:
"issues": {{lookupIssues.key.asJsonStringArray}} ,
"rankBeforeIssue": "{{lookupIssues.first.key}}"
You need juste to check if the the smart value returns an array of the liste of all the issues to Rank, I am not sure about the right syntax, @Bill Sheboy what do you think?
This is my rule:
Have a nice day,
Abir
For the field rankBeforeIssue, only one issue key is expected. And so using the first one from the lookup helps ensure that.
Also...the criteria for your linked issues condition and the lookup issues are different. Thus it is possible the lookup issues could return zero or more issues. (It could return zero due to the possibility of timing issues for the Transition Issue step immediately before the lookup, and so not even the trigger issue is found.)
I recommend two changes:
1) Add criteria to the lookup issues action to exclude the trigger issue with:
AND key != {{triggerIssue.key}}
2) Adding a smart value condition after the lookup to ensure at least 1 issue is found:
These changes will prevent any attempt so re-rank an issue ahead of itself.
Thank you @Abir Brahem and @Bill Sheboy
Is the authorization in my header just email and API key?
Eg firstname.lastname@email.com.au:xxxxxxxxxxxxAPI_KEYxxxxxxxxxxxxxxx
I've added that in authorization header but I get a 401 and have used the same API key before without issue.
Hello @Brendan Betheldo
The autonfication Value filed is:
Basic HzxuhHbhzhdjasYTgdjGfrGHzxuhHbhzhdjasYTgdjGfrG
The key after Basic is YOUEMAIL:API_TOKEN coded id base 64
You can use this online tool to encoded them in base 64
Best Regards,
What was the final version of this PUT body? I have tried both what is included in the above post and screenshot, and I get errors with both.
Hi @Quinn Wood -- Welcome to the Atlassian Community!
Context is important for automation rule questions.
Please post an image of your complete rule, an image of the Send Web Request action, and an image of the audit log details showing your rule execution.
And, where are you observing errors: when creating the rule, when running the rule, something else?
I was able to get this working. Thank you.
I didn't have a valid lookup, so the web request was missing the information.
This was great, @Abir Brahem, thank you!
I was feeling cautious about putting my API key into a public website for encode it. If you're on Mac in terminal, or Unix command line, you can use the base64 command to encode it, like
echo -n 'YOUREMAIL:API_TOKEN' | base64
You probably also want to select the ☑︎ Hidden option as Abir did in the screenshot, but remember to save your API key somewhere else.
So I finally got this working after forever. Steps to complete:
Do I must have a header for this request? How do I get the key to validate the webhook configuration to use smart values substitution?
Hi @Jose Ortega Sorto -- Welcome to the Atlassian Community!
Please see the how-to article posted earlier in this question on how to call the REST API endpoints from a rule using the Send Web Request action.
