×Hi,
I have an automation rule that is filled as an issue picker field, the chosen issue is linked to the issue in which the issue picker field is filled.
Then I will copy the values of various fields from the linked issue in the same rule.
Using {{issue.issuelinks.first.outwardIssue.description}}, {{issue.issuelinks.first.outwardIssue.customfield_14762.key}} etc.
This works with all my fields except an Insight Custom Field.
How can I get an Insight Custom Field in this situation?
Regards, Marco
Hi there,
I have a similar issue on Automation cloud but the other way around.
How to copy an Insight field value to a Text field ?
I have tried the following but obviously it's too easy and not working :)
"fields": {
"customfield_10050": {{customfield_10043}}
customfield_10050 = my text field
customfield_10043 = my insight custom field
Thanks for the help!
@John McKiernan Maybe a bit cheeky to mention you, but do you know a solution for my situation? greetings, Marco
Would you please clarify what is not working? That will help the community provide ideas. Thanks!
Best regards,
I cannot get the copying of an Insight custom field from a linked issue to work. So I am looking for how I can copy the value of an Insight custom field from a linked issue.
Marco
Thanks, Marco.
I am not using Insight, but when I am trying to find/confirm a specific smart value, I use the REST API to pull an example issue and then confirm the value in the JSON. Here is the how-to article for doing that:
https://support.atlassian.com/jira-software-cloud/docs/find-the-smart-value-for-a-field/
__Bill
@Bill Sheboy
Thank you for the information. But my problem is not that I don't know the name or value of the field, but that the " {{issue.issuelinks.first.outwardIssue" function doesn't work on an Insight Custom Field.
So I am looking for how I can copy the value of an Insight Custom Field from a linked issue.
Regards, Marco
I believe .first() is a function for lists, so have you tried:
{{issue.issuelinks.first().outwardIssue}}
And if you know there is only one value you can use:
{{issue.issuelinks.outwardIssue}}
Best regards,
