Copy comments with photo atachments
Kristian Partl July 15, 2021
i have issue with copying comments using automation when i copy comment using smart value {{comment.body}} and that comment including image than automation will not copy that image.
Thanks for help.
Joy Chiu
July 15, 2021
Hi @Kristian Partl
Currently, we don't support copying with attachments.
An improvement ticket is created for this issue. this https://codebarrel.atlassian.net/browse/AUT-2249
Kristian Partl July 16, 2021
Thanks for reply.
Admin Julian Espinoza April 3, 2024
three years later, any movement on this?
Kristian Partl May 14, 2024
@Admin Julian Espinoza you can fix this by using an automation for coping all attachments.
Admin Julian Espinoza May 14, 2024
@Kristian Partl That works quite well initially, but the problem is copying over images in comments placed afterwards. If I put automation in place to copy all attachments again, I end up with duplicate attachments in the issue it's copying to.
If you first use action to delete all attachments and then Copy attachments, it should work.
I have had this done like this and it worked perfectly.
Like • Admin Julian Espinoza likes this
That's a great idea, thank you @Kristian Partl'll test it out and see how it works.
