Dynamically Extract information from Testingborad
Johan van Marion April 29, 2025
For our Robot framework Automation i want to:
from our project (e.g. PRJ)
extract gherkin test steps from the testing board.
The test-case is created with cucumber steps and dataset. (PRJ-001)
The test-case is executed in a execution (PRJ-002)
I'm trying to do this with API and/or GraphQL, but no success as so far...
My question is it possible?
The reason is that we want to have 1 source of information (which is XRAY) for creating test-cases.
I can access the Test-cases and i can access the Test-Executions and get the information
the problem is that when using a dataset linked to cucumber in the testingboard there will be more test-cases/ examples/ iterations which i cannot retrieve.
Johan van Marion April 30, 2025
Finally got it. Pulling :
Project ID with :
query GetProjectId($projectKey: String!) {
getProjectSettings(projectIdOrKey: $projectKey) {
projectId
With this project ID, i can pull the test keys from the repository:
query GetTests($projectId: String!, $path: String!) {
getTests(
projectId: $projectId,
folder: { path: $path, includeDescendants: false },
limit: 50
results {
issueId
testType {
name
jira(fields: ["key"]) # This is the correct way to request Jira fields
Next is getting the individual test-details with :
query GetTestDetails($testKey: String!) {
getTests(jql: $testKey, limit: 1) {
results {
jira(fields: ["key", "summary"])
gherkin
testType {
name
steps {
id
data
action
result
dataset {
parameters {
name
type
rows {
order
Values
Mixing it all together with a little python script and now i'm able to convert the Test-cases (only Cucumber and Manual by the way, as generic is not supported from the cloud with API/GraphQL)
So i've managed to answer my question.
Marc - Devoteam
April 30, 2025
HI @Johan van Marion
Welcome to the community.
Best advice I can give is to contact Xray support on your requirement and see if this is possible.
Sample Test-case:
dataset.png Test-case.png Test-case_execute-in.png Test-execution.png Testingboard.png
Above are extra screenshot on what i want in my scripting to retrieve and how it gets there...
