How can I escape special characters when sending issues comment through a webhook?
Pablo Serra
February 11, 2022 edited
Hi There,
I have a rule that comments issues on a cloud instance with the last comment body of the issues of another cloud instance, by sending {{issue.comments.last.body}} through a webhook:
I'm having some issues with special characters, e.g.:
On the receiving instance I'm getting the following:
Any suggestion on how to handle this kind of comments?
Thanks in advance!
4 votes
March 5, 2022
Hi @Pablo Serra
Have you tried any of the smart value encoding functions provided by automation before sending the message: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/#Encoding
Pablo Serra
Hi Bill, thanks for your reply.
I've contacted support and after a little back and forth, they provided me the following function that did the trick: asJsonString()
In my post:
"commentAuthor": "{{ issue.comments.last.author.displayName }}",
"commentBody": {{ issue.comments.last.body.asJsonString() }},
"keyBancar":"{{ issue.key }}",
"summary":"{{ issue.fields.summary }}",
"keyIssues":"{{ issue.fields.customfield_10716 }}"
Please note that it must be sent without the quotation marks around the curly brackets.
More info about this function:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-json-functions/
Like 3 people like this
Laura Bachiller
January 26, 2024
Hi.
You can also use the json encode function:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/#Json-encoding
{{issue.summary.jsonEncode}}
Like 2 people like this
Graeme Baker
This is really old, but I've been trying to do the same thing lately and came across this article.
All I want to do is comment on an issue in 1 instance, and have that fire off a message to a webhook in Jira automation, and it add that comment to a linked ticket (via custom field).
From above there was a missing colon, and comma:
"comment": {
"id" : "{{comment.id}}",
"body" : {{comment.body.asJsonString()}},
"author" : {
"accountId" : "{{comment.author}}",
"displayName": "{{comment.author.displayName}}"
How do I use an incoming webhook to update a specific issue with this comment from the payload using these smart values?
{{webhookData.comment.body}}
{{webhookData.comment.author.displayName}}
Pablo Serra
Apparently the problem are the line breaks. Only comments with line breaks failed to impact on the receiving instance.
