How can i use Jira automation to update a date field based on another date field
Sameer Mohamed April 23, 2024 edited
Hi Everyone,
I have a field A "date field" and i want to auto populate field B " Which is also a date field".
Example : Field A = Resolution Date then i want to auto update Field B = Closed date.
Whichever date is resolution date i want it to automated as closed date too.
Please share your views on how to do it.
Sameer Mohamed April 27, 2024
Hey everyone,
I have figured out the solution.
I used Trigger as "Field Value Changed"
Then : Edit issue -> Copy "field Value A" to "field Value B"
Requirement is,
Whenever Resolved Date (custom field with dates) is updated then Closed Date field should be automatically updated as same as Resolved Date field.
To achieve this, please guide me.
Hi @Tim Perrault
Thanks for sharing your insight. I tried something with Field Value change as trigger
When : Value Changes for - Resolved Date "2024/04/24"
Then : Edit issue fields - Closed date {{now}}
Is this right?
Tim Perrault
April 23, 2024
Hi @Sameer Mohamed
You could try setting the date field to Now when the issue's resolution field is set or the issue is transitioned to resolved. You can't copy the date, but you could set the date as the relative "now" which would give you as close a date as you could get without the ability to copy.
Hi @Tim Perrault
Is this right?
Additionally what will happen is Resolution date is updated as 2 days later and if we use {{now}} will it pick current date or 2 days later?
Tim Perrault
April 25, 2024
Just want check some things. Is Resolution date the system field or is this a custom field? Is the Resolution date manually set or is it set when you resolve the ticket through the workflow? Is Closed date a custom field?
Sameer Mohamed April 25, 2024 edited
Resolved date is a custom field & Closed date is also a custom field.
Resolution date is manually set, more like updating ETA. If can be current date or week later. Whatever date is set in custom field (Resolved date) then it should reflect in (Closed Date) custom field. All are date fields.
Thanks in advance @Tim Perrault
