×I want to create an automation, which auto schedules tasks (Create an issue + assign it to the team) only on weekdays.
Currently there's no option to choose for weekdays in the "Occurence" field of the automation.
I think you should leave the occurrence at 'Weeks', and simply select all the days in the week you want it to work:
Hi @Naven Kumar
If the answer from Hans solved this, please consider marking the question as "answered". That will help others with similar needs find solutions faster in the future. Thanks!
