How do I copy the value of an issue picker custom field to an issue to be created with Automation for Jira?
When transitioning an issue, I want to create an issue with an Automation for Jira rule. I also want to copy the value of an issue picker custom field from the trigger issue to the issue to be created.
How do I do this?
I've tried with
"customfield_14700": [{
"add": "{{triggerissue.customfield_14700.key}}"but this is not working
Hi Marco,
I probably would use a variable to store the value of the picker, create the new issue and add the value of the variable.
Create variable e.g. "PickerValue" using this Smart value
{{issue.fields.customfield_14700.value}}then create the new issue
and
edit issue field and add your variable there
{{PickerValue}}Hope that helps,
Holger
@Holger Rösch , thanks. it works with a so-called intermediate field.
@Marco Brundel Dear
I'v got the same that your problems.
Did Your function worked?
Can You give me full code?
