How to use Regex to populate Fix Version Field?
Heather Ronnebeck
Hello!
I've got another automation question for everyone. I am trying to do the following:
  • If a custom field (called Platform for this purpose) has iOS as a selected option, then add the unreleased iOS-1.2.3 version to the fix version field.
  • If the same custom field has tvOS as a selected option, then add the unreleased tvOS-2.3.4 version to the fix version field.
Note: The versions will always change, the only thing consistent is that they will all start with either iOS or tvOS and there will only ever be one unreleased version of each kind at any given time.
My idea on this so far has been to attempt this with regex, but I don't think Jira Automation can accept Regex in their lookups. Does anyone have any ideas on this one?
Thanks in Advance!
2 accepted
Darryl Lee
Oh hi @Heather Ronnebeck - yes what @Bill Sheboy said.
Here's the details from a rule I created and tested:
Send Web Request:
https://YOURSITE.atlassian.net/rest/api/3/project/{{issue.project.key}}/versions
Headers:
Content-Type: application/json
Authorization: Basic youremail:token base64encoded
Create variable - {{unreleasedVersions}}
{{#webResponse.body}}{{#if(equals(released, false))}}{{name}}{{^last}},{{/}}{{/}}{{/}}
If: matches - Platform equals iOS
Create variable - {{iOS}}
{{unreleasedVersions.match("(iOS-[^,]*)")}}
Edit issue fields - Advanced
Additional fields:
"fields": {
"fixVersions": [{"name" : "{{iOS}}"}]
Else-if: matches - Platform equals tvOS
Create variable - {{tvOS}}
{{unreleasedVersions.match("(tvOS-[^,]*)")}}
Additional fields:
"fields": {
"fixVersions": [{"name" : "{{tvOS}}"}]
So I did end up using Regex, but only because my filter based on platform didn't work:
{{#unreleasedVersions.split(",")}}{{#if(name(match("iOS-.*").size.gt(0)))}}{{.}}{{/}}{{/}}
I was getting this gnarly error:
Error invoking method com.codebarrel.automation.api.component.smartvalues.objectwrappers.CollectionWrapper.Element.get(java.lang.String@320875173) on com.codebarrel.automation.api.component.smartvalues.objectwrappers.CollectionWrapper.Element@823855090: {{#unreleasedVersions.split(",")}}{{#if(name(match("iOS-.*").size.gt(0)))}}{{.}}{{/}}{{/}}
April 22, 2025
Hi @Darryl Lee
Both the name filtering (by query) and the status filtering may be sent in the original endpoint call using parameters.  Further list filtering may only be needed for more advanced name (or other data attribute) filters.
Thanks, and kind regards,
Darryl Lee
April 22, 2025 edited
Ohey @Bill Sheboy  I looked at the docs for the project versions API endpoint last night and the only query parameters I saw were expand.
OH... but I did not look at the old (v2) endpoints. Get project versions paginated has both query and status parameters you can query. Nifty.
So I guess this could be rewritten (no regex needed) as:
Send Web Request:
https://YOURSITE.atlassian.net/rest/api/2/project/{{issue.project.key}}/version?status=unreleased&query=ios
Headers:
Additional fields:
"fields": {
"fixVersions": [{"name" : "{{webResponse.body.values.first.name}}"}]
Send Web Request:
https://YOURSITE.atlassian.net/rest/api/2/project/{{issue.project.key}}/version?status=unreleased&query=tvos
Headers:
Additional fields:
"fields": {
Two ways to skin a cat. That poor cat. :-D
April 22, 2025
Darryl Lee
How embarrassing, you're completely right, I just didn't scroll up haha.
I guess I should point out that the endpoint is different by an s:
No query parameters:
Query and status parameters:
Tricky.
Heather Ronnebeck
@Darryl Lee and @Bill Sheboy
Thank you so much for the help. It has gotten me 95% of the way there, now there's one last kink in my automation which is the scenario of when there are both tvOS and iOS in the field and both versions need to be mapped into the field.
I have tried using
https://<Yoursite>.atlassian.net/rest/api/2/project/{{issue.project.key}}/version?status=unreleased
this to get the versions, which it does.
But then the issue I run into is that I can't get them into the fix versions field. That's where my hiccup is.
I create the variable of {{apple}} with {{webResponse.body.values.name}} and then use {{apple}} to edit the Fix Version field. However, since it does work it doesn't error out on the audit log, but it also doesn't populate the field. Any ideas?
Darryl Lee
OH that's tricky. So MAYBE, just maybe instead of doing:
  • IF iOS
  • ELSE tvOS
You instead do:
  • IF iOS
    • WebRequest to get iOS version
    • ADD version to fixVersions (instead of current REPLACE)
  • ELSE
    • audit log saying not iOS
  • IF tvOS
    • WebRequest to get tvOS version
  • ELSE
    • audit log saying not tvOS
Let me give that a spin.
Darryl Lee
April 24, 2025 edited
Ah yeah, it works. Here's the iOS IF branch after I created a new IF branch for tvOS and dragged all the actions down to it.
New JSON for adding fixVersions:
"update": {
"fixVersions": [{
"add" : {
"name" : "{{iOS}}"
Heather Ronnebeck
More like:
  • IF iOS
  • IF tvOS
  • ELSE
Would that work?
Heather Ronnebeck
I got it!!! It works!!
So what I needed to do was add a few re-fetchs in there and then also make sure I checked off the checkbox for:
Delay execution of subsequent rule actions until we've received a response for this web request
The part that I was stumbling on before you last update @Darryl Lee was the add vs replace.
@Bill Sheboy @Darryl Lee thank you so much for this help. I appreciate it.
Like • Bill Sheboy likes this
Darryl Lee
I think if you do two IF-ELSES then both will complete, and you'll get what you want.
I don't think I can advise removing the Delay. You absolutely need to WAIT for the response back from the API before trying to set the version.
I'm surprised if what you wrote worked, @Heather Ronnebeck because historically, if an IF clause failed, the rule would stop. So if the issue only had tvOS, it might not get set. That's why I added the ELSE.
@Bill Sheboy is that your recollection to how IFs used to work?
If Automation has changed how it deals with failed IFs, then... what you could get rid of is your last ELSE statement.
April 25, 2025
With the if / else condition, the sections are apparently mutually exclusive: only one (or none) will execute, and...an if / else condition will not halt rule execution.  This is based on my testing / observation.
Heather Ronnebeck
And now this story has another chapter.....
So we've been running this rule for a week, and found a hiccup with it. It appears that they actually don't have just 2 versions (1 for each), so we need the automation to pull in the latest version created that starts with either ios or tvos.
So what I've been trying to do myself is see if I can pull in .latest or something similar in the web response values.
Do you guys have any suggestions?
May 2, 2025
Hi, Heather!
Without seeing your current / most recent rule...
If you are using the REST API endpoint to get the versions, there is an orderBy parameter which could be used to sort by the releaseDate.  With that, the specific one could be grabbed using the .last list function.
Heather Ronnebeck
Here is the rule in it's full working glory before this requirement.
What I found is that the Web Responses were pulling in more than one ios and more than one tvos fix version now that is unreleased.
May 2, 2025
Thanks for the updated rule image, and that seems to support try adding the orderBy parameter to the Send Web Request actions, and then getting the last one from the list / responses returned.
Remember to add the parameters you are using in the same ordering shown in the documentation:
  • orderBy
  • query
  • status
Heather Ronnebeck
Thank you @Bill Sheboy !!! That's exactly what I needed. I kept doing latest instead of last which was what was throwing me off.
April 22, 2025
Hi @Heather Ronnebeck
Short answer: the rule will need to use the REST API endpoint (with the Send Web Request action) to find the version to add, filtering by the name prefix and the status, and then add it using JSON.
Pablo Vergara
April 22, 2025
Have you tried something like the example below? I'm using a multi-select list field for testing (customfield_10157 in the images). It also uses regex; you can add another IF condition for the iOS matches.
I hope it's helpful as guidance for you!
- Pablo
