In Jira Software Automation how to send "Customised Email" with URL Link of the Jira Item in Rich
Calvin
September 15, 2025
Hi all, not sure if I'm just misunderstanding this but basically I have text like
  • Hi team your Jira Item is: abc-xxxx
Where abc-xxxx should be a link to the ticket. But for some reason I can't figure out how in the "Customised Email" function as rich text. I can do this in a normal email as I have access to the HTML tags, but how do I do this in a "Customised Email".
Marc - Devoteam
September 17, 2025
Hi @Calvin
I think this is based on the content format option chosen, as mentioned by @Varsha Joshi
For HTML, this should apply: <a href="{{issue.url}}">{{issue.key}}</a>
For Rich Text, this should probably be: [{{issue.key}}](issue.url)]
Calvin
September 17, 2025
Thanks Marc, indeed it works for HTML which I think I may have to end up doing in the end.
But was hoping to get Rich Text working as I know it would make future email notifications easier. The following is what I get:
and View if i make sure the automation uses the smart thing:
Marc - Devoteam
September 17, 2025
Hi @Calvin
You need to try: [{{issue.key}}|(issue.url)]
I had a typo in my previous response, the separator between the name and url needs to be a pipe symbol.
September 27, 2025
Hi @Calvin
Just following up to check if the suggestions from Marc answered your question.  If so, please consider marking this one as "answered".  That will help others with a similar need find solutions faster.  If not, please let the community know what help you need with the rule changes.
Varsha Joshi
I think you should pick HTML format.
Staffan Redelius
September 16, 2025
Hi @Calvin
It should be possible to use:
Hi team your Jira Item is: <a href="{{issue.url}}">{{issue.key}}</a>
Some companies has quite a strict handling of hyperlinks in emails due to the risk of "spoofing" so it might be handled as insecure.
Best regards,
/Staffan
Calvin
September 16, 2025
Thats what I would have thought too, but even on my own personal instance I seem to have a similar issue:
