×Hi,
i have problems creating an automation in insight.
When a Jira Issue is updated, the actual date should be inserted into a date field. When I change the "Then" field to a status or text change, the automation works.
What I am trying to do is, that the the actual date should be written into a date- or textfield.
Is it possible to this with a simple automation? I'm not familar in scripting.
Many thanks for helping me out.
In documentation says for support "Placeholders"
I try to use ${update} from Advanced: Placeholders,
but date not set to attribut
now() is not supported , but is an actual date supported?
