Releasing multiple versions from a single issue.
Heather Ronnebeck
Hey,
What I'm trying to do is create an automation that does the following:
  1. Upon being triggered by a ticket being closed, checks to see if there are any fix versions attached to the ticket.
  2. Grabs the names of all versions in the fix version field on the trigger ticket.
  3. Checks each version listed to see if there are any remaining open tickets.
  4. If no remaining tickets, release the version.
I had this working when there was 1 version in the fix version field, but as I'm learning, the users are having multiple versions and now I can't get the branching and array working to have each version checked in steps 3 and 4 (if applicable).
This is one of the lookup queries I've tried for step 2.
  fixversion in ( {{triggerissue.fixVersions.name.asJsonString.asJsonArray}} ) AND statuscategory NOT IN (Done)
Does anyone have any suggestions on how I can accomplish this? I am running in to the wall here.
Thank you!
Andrea Robbins
Hi @Heather Ronnebeck
Here's my thoughts:
1. When ticket is resolved
2. Go through each fix version
3. Do a issue lookup to see if any issues are still open
4. If none are open, release that Fix Version
See screenshotsScreenshot 2025-03-27 at 3.43.40 PM.png Screenshot 2025-03-27 at 3.44.37 PM.png Screenshot 2025-03-27 at 3.44.47 PM.png
Note for the LookupIssues it needs to be "fixVersion in ({{fixVersionVar.id}}) AND resolution is empty" (screenshot says fixVersions it needs to be singular). Note also I haven't tested this (haven't saved it) so please let me know if this works as expected :)
Heather Ronnebeck
Hey,
The issue I'm running into is that it's not having a good time pulling out those fix versions. It seems to not be able to make it an object.
Andrea Robbins
March 27, 2025 edited
Just tested the rule in my environment. Make two minor adjustments:
- Change {{lookupIssues}} to {{lookupIssues.size}} in the If: Compare two values
- Change fixversions to fixVersion in the JQL
Andrea Robbins
Also see if the For each: Smart value is set up as shown in the screenshot. It should only show one fix version id. It goes through each one mentioned on the issue one by one, so it knows which one to close
EDIT: I see your error now more clearly - make sure the lookup Issues component is within the branch or it won't work as expected
Heather Ronnebeck
Hey @Andrea Robbins
I did the updates you're suggesting, but I am still getting the error that the provided smart value couldn't be resolved to be an object.
I think I'm doing something wrong at the Branching step.
March 28, 2025
Heather, would you please post an image of your current complete rule and of the audit log details showing the execution (with all of the areas at the right side expanded)?  That context may help explain what you are observing.  Thanks!
April 8, 2025
Just following up to check if this answered your question.  If so, please consider marking this one as "answered".  That will help others with a similar need find solutions faster.  If not, please let the community know what help you need with the rule changes.
Like • Andrea Robbins likes this
Heather Ronnebeck
Hey @Bill Sheboy
I'm just traveling right now from Team so I haven't had a chance to look at this again in a while. As soon as I can I'll post the automation and we can continue working on it.
Thank you again!
Like • 2 people like this
Heather Ronnebeck
Screenshot 2025-04-15 at 5.26.38 PM.png Screenshot 2025-04-15 at 5.26.46 PM.png
@Bill Sheboy @Andrea Robbins Here's the rule in its current state. I hope this helps. I haven't touched it since we last spoke.
April 15, 2025
Thanks for the rule image, and let's adjust some things...
First, smart values are name, spacing, and case sensitive, and the one for the Fix Versions field is {{issue.fixVersions}} so please update your log statements and the advanced branch.
Next, let's simplify the branching and only use the ID values (as those will be needed later for releasing.  Thus for the advanced branch smart value, we can use the new flatten function to combine the values (from the lists-of-lists) and get the distinct ones:
  • advanced branch
    • smart value: {{lookupIssues.fixVersions.id.flatten.distinct}}
    • variable name: fixVersionIDVar
I added ID to the variable name to make it obvious what value it contains.  Then change the JQL for Lookup Issue inside the branch, and follow that by a condition to confirm no issues remain.  Please note well: the JQL was missing the NOT to confirm there are no remaining issues active in the version.
  • action: lookup issues
    • fixVersion IN ( {{fixVersionIDVar}} ) AND Resolution IS NOT EMPTY
  • smart values condition
    • first value: {{lookupIssues.size}}
    • condition: equals
    • second value: 0
  • action: release the version, {{fixVersionIDVar}}
Andrea Robbins
Hi all! Few things:
  1. @Bill Sheboy is correct - make sure your smart values are using the right case - it is lookupIssues and fixVersions.
  2. There is no need to flatten out the fix version ids in the advanced branching, I just did {{issue.fixVersions}}. You actually don't want to flatten it out so you have access to both the id and the name to use for later.
  3. In the lookup issues part, you actually want it to say "fixVersion in ({{fixVersionVar.id}}) AND resolution is empty" (do not include the NOT) - what we are doing is seeing if there are any tickets that are still open - if there are 0 tickets that are open, then release the fix version as all of the ticket are closed.
  4. The Advanced branch needs to be {{issue.fixVersions}} there isn't a lookupIssues smart value available until after you use the lookup issues component which is within the branch.
  5. The release component actually needs the name and not the id:
Heather Ronnebeck
@Andrea Robbins I noticed that you have other steps in the automation branch that aren't in your screenshot. Am I missing other steps? I am getting new errors now. Now we can't find the release version at all.
Heather Ronnebeck
I think we got it.
This is the final rule for anyone else that needs it. Thank you so much @Bill Sheboy and @Andrea Robbins
Screenshot 2025-04-21 at 10.44.30 PM.png Screenshot 2025-04-21 at 10.44.52 PM.png
Andrea Robbins
Yay! Happy to help
Without seeing your entire rule (and audit log details) for context...
What is the purpose of the asJsonArray added to the end of the expression?  I would expect using just asJsonString would be sufficient to produce the CSV list:
fixVersion IN ( {{triggerIssue.fixVersions.name.asJsonString}} ) ...
And...what is the scope of the rule: single-project, multiple-project, or global?  For other than single-project, perhaps use the version ID rather than the names to reduce the risk of collisions.
fixVersion IN ( {{triggerIssue.fixVersions.id.join(", ")}} ) ...
UPDATED: please see the post below using the new flatten function to merge the version values from lists-of-lists into a single list of version ID values:
https://community.atlassian.com/forums/Automation-questions/Re-Re-Releasing-multiple-versions-from-a-single-issue/qaq-p/2999095/comment-id/13947#M13947
Heather Ronnebeck
I was trying to pull out when there were two fix versions vs one in the rule. This is for a single project scope.
Heather Ronnebeck
The format you provided did help a bit, but the error I got was "The provided smart value couldn't be resolved to an object"
March 28, 2025
Hi, Heather.  Rather than suggesting two different approaches, please continue with the thread with Andrea and I will pitch in to help if an alternative is needed.
