When I use the Rovo Agent directly, the response is formatted correctly. However, when invoking the same agent via Jira Automation and inserting {{agentResponse}}
into the Description field, the formatting breaks. Interestingly, the response appears perfectly formatted when added as a comment instead.
Does anyone have any insights into why this might be happening?
Welcome to the community.
What is the agent doing in the automation, does it make a new issue?
The edit action is related to the sub-task in the branch, it will not act on the created issue, if that is what the Rovo agent does.
