assignee.displayName doesn't display Unassigned when the issues isn't assigned
Neil Jones September 24, 2020
When writing a slack or email message from Jira Automation I am trying to display the assigned user or an issue in the email/slack message using {{assignee.displayName}} but if the issue is unassigned is doesn't display anything. Is there a way to get it to display "Unassigned" like it would in Jira?
Neil
Sherry Goyal
September 27, 2020 edited
Hello @Neil Jones
Please try using:
{{assignee.displayName | Unassigned}}
If displayName is unset, "Unassigned" will serve as fallback value.
Hope this helps.
Cheers
Sherry(A4j)
Patricia Francezi
I wish we have more docs about smart values :(
Like • 2 people like this
Neil Jones September 28, 2020
This worked perfectly, thanks
Gabi Zavilla February 8, 2022
This doesn't work for me I'm afraid. The assignee is shown but the Unassigned is not. Any ideas why this could be? I looked for an answer elsewhere but there is nothing out there.
Lubomir Kosaristan March 29, 2022
Hi @Gabi Zavilla
the syntax of example is a bit off, try this: {{assignee.displayName|"Unassigned"}} it should work (at least it works for me) :)
Like • 3 people like this
Gabi Zavilla March 29, 2022
Thank you @Lubomir Kosaristan
Gabi Zavilla April 6, 2022
This worked a perfect treat, thank you again!
Like • Lubomir Kosaristan likes this
Patricia Francezi
Hi @Neil Jones
What I would do is to perform a condition in the rule (a branch).
If assignee is empty send X message
If assignee is not empty send y message.
Its normal not showing anything, as you are resquesting a value, and in Unassigned issue the information is not really present.
I hope this helps
Neil Jones September 28, 2020 edited
Thanks for the help
